Dell Chromebook 11 3120 Intel Celeron N2840 4GB 16GB SSD 11.6" Chrome OS
Quicklinx: BGNMWS00 Mfr#: 3120-8524
  • Celeron
  • Bluetooth 4.0
  • IEEE 802.11n
Affordable, practical and user-friendly, the Dell Chromebook 11 could be the ideal option for you if you're looking for performance on a budget.
This Chromebook laptop comes equipped with a range of premium features, including multiple layers of security to keep all those essential files and sensitive personal information safe under lock and key. Updates are installed automatically, entirely for free.
Dell's Chromebook 11 is simple to use and only takes a few seconds to boot up - so you could be away and working (or playing) in next to no time. Consuming and creating content, connecting with friends and colleagues, and creating and editing documents are all totally easy.
It's powered by a 2.16GHz Intel Celeron processor, and is equipped with 4GB RAM and 16GB SSD storage space - so there'll be more than enough room for all your must-have files. The Chromebook 11's high-density battery gives you seven hours of power, so you can keep going almost all day if you need to.
This model proves that performance and power needn't come at the expense of affordability.
  • Spill protection
    A fully sealed keyboard and touch pad provide the industry's best spill protection.
  • Lightweight design
    At under three pounds with a compact 11.6" display, it's easy to pop it in a bag and get going so you can get things done anywhere.
  • Flexible viewing
    Easily share the screen when working together on homework. A 180-degree LCD hinge reduces stress on the lid and lets it lay flat. Plus, the anti-glare HD LCD screen keeps your screen visible in any light.
  • Easy to hear
    Whether you are watching a movie, video chatting with a friend or playing music, the dual-array microphones and front-facing speakers make it easy to hear and be heard.
  • Excellent battery life
    With state-of-the-art battery life, you can feel confident diving into big tasks while you're unplugged.
  • Automatically secure
    Stay online with minimal risk. Apps and data are automatically scanned for malware in the cloud, so your Chromebook stays safe without any additional security software.
Dell Chromebook 3120 - 11.6" - Intel Celeron - N2840 - 4 GB RAM - 16 GB eMMC - UK
Chromebook
Operating System
Chrome OS
Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
4 GB DDR3L
Storage
16 GB eMMC
Display
11.6" 1366 x 768 / HD
Graphics
Intel HD Graphics
Keyboard
Integrated Webcam
Bluetooth 4.0, 802.11a/b/g/n/ac
3-cell
Blue
Image Colour Disclaimer
The displayed product image may be a different colour
29.7 cm x 21.7 cm x 2.1 cm
1.266 kg
Limited warranty - 1 year
Bundled Services
1 Year Dell Collect and Return Service
Chromebook
Operating System
Google Chrome OS
Processor / Chipset
CPU
Max Turbo Speed
2.58 GHz
Number of Cores
Dual-Core
Cache
L2 - 1 MB
64-bit Computing
Intel Burst Technology
RAM
4 GB
Max RAM Supported
4 GB
DDR3L SDRAM
Storage
Main Storage
16 GB eMMC
Display
11.6"
Resolution
1366 x 768 (HD)
Widescreen
Image Aspect Ratio
16:9
Image Brightness
220 cd/m²
Audio & Video
Graphics Processor
Intel HD Graphics
Camera
Yes - 1280 x 720
Resolution
0.92 Megapixel
Camera Features
720p HD movie recording
Sound
Microphone
High Definition Audio
Input
Keyboard, touchpad
Keyboard Layout
Communications
Wireless
Wireless Controller
Intel Dual Band Wireless-AC 7260
3-cell
AC Adapter
Input
Output
65 Watt, 19.5 V, 6.67 A
Connections & Expansion
Headphone/microphone combo jack , HDMI , USB 3.0 , USB 2.0
Memory Card Reader
Yes (SD Card)
Blue
1 USB 3.0 charging port
Power adapter
1.266 kg
Bundled Services
10 - 90% (non-condensing)
BGNM C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
BGNM Jabra Stealth UC Bluetooth Headset In Stock £89.07
