Affordable, practical and user-friendly, the Dell Chromebook 11 could be the ideal option for you if you're looking for performance on a budget.
This Chromebook laptop comes equipped with a range of premium features, including multiple layers of security to keep all those essential files and sensitive personal information safe under lock and key. Updates are installed automatically, entirely for free.
Dell's Chromebook 11 is simple to use and only takes a few seconds to boot up - so you could be away and working (or playing) in next to no time. Consuming and creating content, connecting with friends and colleagues, and creating and editing documents are all totally easy.
It's powered by a 2.16GHz Intel Celeron processor, and is equipped with 4GB RAM and 16GB SSD storage space - so there'll be more than enough room for all your must-have files. The Chromebook 11's high-density battery gives you seven hours of power, so you can keep going almost all day if you need to.
This model proves that performance and power needn't come at the expense of affordability.
Spill protection
A fully sealed keyboard and touch pad provide the industry's best spill protection. -
Lightweight design
At under three pounds with a compact 11.6" display, it's easy to pop it in a bag and get going so you can get things done anywhere. -
Flexible viewing
Easily share the screen when working together on homework. A 180-degree LCD hinge reduces stress on the lid and lets it lay flat. Plus, the anti-glare HD LCD screen keeps your screen visible in any light. -
Easy to hear
Whether you are watching a movie, video chatting with a friend or playing music, the dual-array microphones and front-facing speakers make it easy to hear and be heard. -
Excellent battery life
With state-of-the-art battery life, you can feel confident diving into big tasks while you're unplugged. -
Automatically secure
Stay online with minimal risk. Apps and data are automatically scanned for malware in the cloud, so your Chromebook stays safe without any additional security software.
- Dell Chromebook 3120 - 11.6" - Intel Celeron - N2840 - 4 GB RAM - 16 GB eMMC - UK
- Product Type
- Chromebook
- Operating System
- Chrome OS
- Processor
- Intel Celeron N2840 / 2.16 GHz, up to 2.58 GHz / 1 MB Cache
- Memory
- 4 GB DDR3L
- Storage
- 16 GB eMMC
- Display
- 11.6" 1366 x 768 / HD
- Graphics
- Intel HD Graphics
- Keyboard
- UK
- Integrated Webcam
- Networking
- Bluetooth 4.0, 802.11a/b/g/n/ac
- Battery
- 3-cell
- Blue
- Image Colour Disclaimer
- The displayed product image may be a different colour
- 29.7 cm x 21.7 cm x 2.1 cm
- 1.266 kg
- Limited warranty - 1 year
- Bundled Services
- 1 Year Dell Collect and Return Service
- Product Type
- Chromebook
- Operating System
- Google Chrome OS
Processor / Chipset
- CPU
- Max Turbo Speed
- 2.58 GHz
- Number of Cores
- Dual-Core
- Cache
- L2 - 1 MB
- 64-bit Computing
- Intel Burst Technology
- RAM
- 4 GB
- Max RAM Supported
- 4 GB
- Technology
- DDR3L SDRAM
Storage
- Main Storage
- 16 GB eMMC
Display
- 11.6"
- Resolution
- 1366 x 768 (HD)
- Widescreen
- Image Aspect Ratio
- 16:9
- Image Brightness
- 220 cd/m²
Audio & Video
- Graphics Processor
- Intel HD Graphics
- Camera
- Yes - 1280 x 720
- Resolution
- 0.92 Megapixel
- Camera Features
- 720p HD movie recording
- Sound
- Microphone
- High Definition Audio
Input
- Keyboard, touchpad
- Keyboard Layout
- UK
Communications
- Wireless
- Wireless Controller
- Intel Dual Band Wireless-AC 7260
- Technology
- 3-cell
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 65 Watt, 19.5 V, 6.67 A
Connections & Expansion
- Headphone/microphone combo jack , HDMI , USB 3.0 , USB 2.0
- Memory Card Reader
- Yes (SD Card)
- Blue
- 1 USB 3.0 charging port
- Included Accessories
- Power adapter
- 1.266 kg
- Bundled Services
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
Jabra Stealth UC Bluetooth Headset | In Stock | £89.07 |
