Product
Dell Cable for PERC H200 Controller for T110 II Chassis - Kit
Quicklinx: 9957WS00 Mfr#: 470-12373
The battery cable from Dell helps connect battery to your PERC H200 controller card. The product is an ideal choice for expanding your backup capacity using a single PERC controller card and also for high speed connectivity.
Dell SAS internal cable kit
Dell PERC H200, PERC H200 Integrated / Adapter; PowerEdge T110 II
Storage Cable Type
Dell PERC H200, PERC H200 Integrated / Adapter , Dell PowerEdge T110 II
