Boost efficiency with a robust multifunction printer featuring embedded document solutions, enterprise-level security and outstanding reliability. Ideal for large workgroups, the C5765dn delivers superb print, scan and copy performance, long-term reliability and low overall cost of ownership.
Automate and simplify jobs
Get tasks done efficiently with robust document and workflow solutions built into a high-performance, color multifunction printer. -
Exceptional performance, reliability and value
Ideal for large workgroups, the C5765dn delivers superb print, scan and copy performance, long-term reliability and low overall cost of ownership. -
Enterprise-level security for strong data protection
Protect sensitive information without disrupting your workflow with powerful security functions. -
Easy to use and highly customizable
Simplify tasks and save time with intuitive and customizable features. Easily extend your capabilities with input and finishing options.
- Dell C5765dn - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 110000 impressions
- Max Copying Speed
- Up to 45 ppm (mono) / up to 45 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 7"
- Document Feeder Capacity
- 110 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper
- Standard Media Capacity
- 700 sheets
- Max Media Capacity
- 2350 sheets
- Bypass Feeder Capacity
- 150 sheets
- Output Trays Capacity
- 500 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB host
- Office Machine Features
- Save to USB flash drive, scan to e-mail, scan to folder, scan to network
- 56 cm x 53.6 cm x 63 cm
- 56 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- EPEAT Bronze, ENERGY STAR Qualified
- 1-year warranty
- Laser - colour
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 512 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Preset Enlargements
- 400%
- Preset Reductions
- 25%
- Maximum Copies
- 999
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, XPS
- First Print Out Time B/W
- 5 sec
- First Print Out Time Colour
- 7 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 2400 x 2400 dpi
Document & Media Handling
- 110 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 216 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese postcard (100 x 148 mm)
- 700 sheets
- 2350 sheets
- 150 sheets
- 500 sheets
- Input tray - 550 sheets size: 99 x 191 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Bypass tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 500 sheets size: 139.7 x 210 mm - Legal (216 x 356 mm) , ADF - 110 sheets
- Speed Details
- Printing: up to 45 ppm (A4) - colour , Printing: up to 45 ppm (A4) - B/W , Printing: up to 47 ppm (Letter A) - colour , Printing: up to 47 ppm (Letter A) - B/W , Copying: up to 45 ppm , Scanning: up to 45 ipm - colour duplex
- 1 x USB 2.0 , 1 x Gigabit LAN , 2 x USB host
- Kerberos, LDAP, AES-256
- Operating System Support
- MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows 7 64-bit Edition, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Windows 8 64-bit
- Software Included
- Drivers & Utilities
- CSA, CISPR 24, DHHS, EN55022, ICES-003, NEMKO, EN55024, RoHS, IEC 60950-1, EN 60950-1, WEEE, IEC 60825-1, FDA, FCC CFR47 Part 15 B, Energy-Related Products (ErP) Lot 6, EMC Class B, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009
- EPEAT Compliant
- EPEAT Bronze
- ENERGY STAR Certified
- Limited warranty - 1 year
- 56 cm
- 53.6 cm
- 63 cm
- 56 kg
- Shipping Width
- 70.5 cm
- Shipping Depth
- 76.8 cm
- Shipping Height
- 84.5 cm
- Shipping Weight
- 69 kg
