Product
Brand
Dell C5765DN Colour Networked Laser Printer
Quicklinx: 9DMXWS00 Mfr#: 210-ABSY
Boost efficiency with a robust multifunction printer featuring embedded document solutions, enterprise-level security and outstanding reliability. Ideal for large workgroups, the C5765dn delivers superb print, scan and copy performance, long-term reliability and low overall cost of ownership.
Dell Multifunction Color Laser Printer C5765dn - multifunction printer (colour)
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
110000 impressions
Max Copying Speed
Up to 45 ppm (mono) / up to 45 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
7"
Document Feeder Capacity
110 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, cards, labels, recycled paper, coated paper
Standard Media Capacity
700 sheets
Max Media Capacity
2350 sheets
Bypass Feeder Capacity
150 sheets
Output Trays Capacity
500 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network
56 cm x 53.6 cm x 63 cm
56 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified, EPEAT Bronze
1 year warranty
Printing Technology
Laser - colour
110000 impressions
Display Diagonal Size
7"
Display Features
Touch screen
Standard Memory
512 MB
Supported Flash Memory
USB flash drive
Copying
Max Copying Speed
Preset Enlargements
400%
Preset Reductions
25%
Maximum Copies
999
Automatic Duplexing
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PostScript 3, XPS
Automatic Duplexing
First Print Out Time B/W
5 sec
First Print Out Time Colour
7 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Interpolated Resolution
2400 x 2400 dpi
Document & Media Handling
110 sheets
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
216 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Folio (216 x 330 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm), Japanese postcard (100 x 148 mm)
700 sheets
Max Media Capacity
2350 sheets
150 sheets
500 sheets
Input tray - 550 sheets size: 99 x 191 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Bypass tray - 150 sheets size: 76 x 127 mm - Legal (216 x 356 mm) weight: 60 g/m² - 216 g/m² , Output tray - 500 sheets size: 139.7 x 210 mm - Legal (216 x 356 mm) , ADF - 110 sheets
Speed Details
Printing: up to 45 ppm (A4) - colour , Printing: up to 45 ppm (A4) - B/W , Printing: up to 47 ppm (Letter A) - colour , Printing: up to 47 ppm (Letter A) - B/W , Copying: up to 45 ppm , Scanning: up to 45 ipm - colour duplex
1 x USB 2.0 , 1 x Gigabit LAN , 2 x USB host
Security Protocols & Features
Kerberos, LDAP, AES-256
Operating System Support
MS Windows XP, UNIX, Linux, MS Windows Server 2003, MS Windows 7, MS Windows 7 64-bit Edition, Apple MacOS X 10.4 or later, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Server 2003 x64 Edition, MS Windows Vista (64-bit versions), MS Windows Server 2008, MS Windows Server 2008 R2, Windows 8, Windows 8 64-bit
Software Included
Drivers & Utilities
CSA, CISPR 24, DHHS, EN55022, ICES-003, NEMKO, EN55024, RoHS, IEC 60950-1, EN 60950-1, WEEE, IEC 60825-1, FDA, FCC CFR47 Part 15 B, Energy-Related Products (ErP) Lot 6, EMC Class B, EN 61000-3-3:2008, EN 61000-3-2:2006+A1:2009+A2:2009
EPEAT Compliant
EPEAT Bronze
ENERGY STAR Certified
Limited warranty - 1 year
56 cm
53.6 cm
63 cm
56 kg
Shipping Width
70.5 cm
Shipping Depth
76.8 cm
Shipping Height
84.5 cm
Shipping Weight
69 kg
9DMX C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.16
9DMX C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.25
9DMX C2G 2m Cat6a Shielded Patch - Blue In Stock £7.00
9DMX C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £43.89
