Brand
Dell C5519Q 55" 4K 3840X2160 HDMI VGA LED Large formal Display
Quicklinx: F16LWS00 Mfr#: DELL-C5519Q
Video Interface: HDMI
TV Tuner Presence: No
  • USB
£760.04 ex VAT
£912.04 inc VAT
Foster collaboration while maintaining control of your meeting with this 55" 4K large format monitor.
  • Stunning visuals, striking presentations
    Experience exceptionally sharp text and images with 4K resolution on a large format monitor that is optimized for text.
  • More ways to display
    Conveniently select from predefined templates with the Easy Arrange feature on Dell Display Manager Software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off.
  • Dynamic colors, crisp details
    A wide 178°/178° viewing angle lets you and your team see fine details and vibrant colors from either side of the room.
  • Stay on schedule
    Keep your meetings on track with a wide range of ports that allow you to easily connect and transition between presenters.
  • Simplify your control
    Automatically wake-up and shutdown your monitor and other devices while connected to compatible HDMI CEC devices.
  • Lock it down
    Reduce display changes in high traffic environments with lock mode, a feature that allows IT to control menu and power options.
Dell C5519Q 55" Class (54.6" viewable) LED-backlit LCD display - 4K - for conference
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - conference
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15), DisplayPort, USB
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Picture Enhancements
72% Color Gamut (CIE 1931)
USB
3 ports
Remote control, wireless remote control, 3 x wire saddles
Voltage
120 Watt
Power Consumption (On mode)
100 W
Energy Consumption per Year
143 kWh
Dimensions (WxDxH) - panel
124.1 cm x 6.48 cm x 72.15 cm
20.5 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
3 years Advanced Exchange Service and Limited Hardware Warranty
120 Watt
100 W
143 kWh
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - conference
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Dimensions
Panel
124.1 cm
6.48 cm
72.15 cm
20.5 kg
Display
Resolution
3840 x 2160
Display Format
4K UHD (2160p)
Image Aspect Ratio
16:9
LED backlight
Coating
Anti-glare, 3H Hard, 2% haze
Dynamic Contrast Ratio
4000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Stands & Mounts
Flat Panel Mount Interface
400 x 400 mm
VESA Compatibility
Media Player
USB Port
USB Ports Qty
3
Remote Control
Remote control
Connector Type
2 x HDMI , DisplayPort , VGA input , Audio line-in , Audio line-out , USB 3.0 upstream , 2 x USB 3.0 downstream , RS-232 , USB 3.0 with battery charging , LAN
Wireless remote control, 3 x wire saddles
VGA cable - 3 m , HDMI cable - 3 m , SuperSpeed USB cable - 3 m , DisplayPort cable - 3 m
RoHS
TCO Certified
ENERGY STAR Certified
Power supply
Input Voltage
Power Consumption (Off Mode)
0.5 Watt
On / Off Switch
No
Bundled Services
Weight (Shipping)
27.57 kg
10 - 80% (non-condensing)
Brand: Dell
Price Range Ex VAT: £750 - £1000
Stock Status: In stock
