Dell C5517H 55" 1920 x 1080 8ms VGA HDMI DisplayPort Black LFD
Quicklinx: CGVMWS00 Mfr#: C5517H
  • 1080p
Bring incredible viewing to your conference rooms with a 55-inch monitor that's perfect for small meetings with an audience of 4-8 people.
  • A display as bright as your ideas
    See your work in a light with incredible on-screen clarity and bright imagery, even in fully lit meeting rooms.
  • Convenient and easy to use
    Set up your next presentation quickly and easily with the mainstay of your meeting room.
  • Reliable performance, eco-conscious design
    A smart, environmentally friendly design make this reliable monitor a great addition to any small meeting room.
Dell C5517H 55" Class (54.6" viewable) LED-backlit LCD display - Full HD - for interactive communication
LED-backlit LCD flat panel display
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Bundled with
3 years Advanced Exchange
Resolution
1920 x 1080
Display Format
1080p
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
VGA (HD-15), DisplayPort
LCD Backlight Technology
LED backlight
Image Aspect Ratio
16:9
TV Tuner
No tuner
Speaker System
2 speakers
Remote control, 2 AAA batteries, wireless remote control, 3 cable clips, 4 x M4 (12 mm) screws
Voltage
Energy Class
Class A+
170 Watt
Power Consumption Stand by
0.3 Watt
Energy Consumption per Year
50 kWh
124.1 cm x 24.5 cm x 78.86 cm
24.6 kg
3-year warranty
Energy Class
Class A+
170 Watt
50 kWh
Diagonal Class
55"
Diagonal Size
54.6"
Commercial Use
Yes - interactive
Bundled with
TV Tuner
No tuner
TV Tuner Presence
No
Video Interface
HDMI
HDMI Ports Qty
2 ports
PC Interface
Dimensions
With stand
124.1 cm
24.5 cm
78.86 cm
24.6 kg
Enclosure Colour
Display
Resolution
1920 x 1080
Display Format
1080p
Image Aspect Ratio
16:9
LED backlight
Coating
3H Hard
Image Contrast Ratio
3000:1
Brightness
350 cd/m²
Viewing Angle
178 degrees
Viewing Angle (Vertical)
178 degrees
Response Time
8 ms
Anti-glare coating, security lock slot (cable lock sold separately), built-in USB charging port
Stands & Mounts
Stand
Included
Flat Panel Mount Interface
400 x 400 mm
Remote Control
Remote control
Audio System
Speaker System
2 speakers
Connector Type
Serial , DisplayPort , Audio line-out , Audio line-in , 2 x HDMI , 3 x USB 3.0 downstream , USB 3.0 upstream , VGA input
Security Slot Type
Kensington security slot
VGA cable - 3 m , HDMI cable - 3 m , USB cable - 3 m , DisplayPort cable - 3 m
Plug and Play, DDC/CI, RoHS, halogen-free, BFR-free
Power supply
Input Voltage
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Limited warranty - 3 years
Dimensions & Weight Details
Panel with stand - 124.1 cm x 24.5 cm x 78.86 cm x 24.6 kg , Panel without stand - 124.1 cm x 6.48 cm x 72.15 cm x 20.4 kg
Weight (Shipping)
32.2 kg
20 - 80% (non-condensing)
