The QLogic 5720 DP 1Gb PCI Network Interface Card in a low-profile form factor from Dell is responsible for connecting your desktop and server to your network. Its Remote management support enables you to maximize management resources.
- Broadcom 5720 - Customer Kit - network adapter - PCIe - Gigabit Ethernet x 2
- Network adapter
- Form Factor
- Plug-in card - low profile
- Interface (Bus) Type
- PCI Express
- Ports
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Processor
- 1 x Broadcom BCM5720
- Designed For
- PowerEdge C6420, FC430, FC630, R320, R420, R420xr, R520, R620, R720, R720xd, R820, VRTX, VRTX M520, VRTX M620
- Network adapter
- Form Factor
- PCI Express
- Ports
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
Processor / Memory
- Processor
- 2 x 1000Base-T - RJ-45
- Designed For
- Dell PowerEdge C6420, FC430, FC630, R320, R420, R420xr, R520, R620, R720, R720xd, R820, VRTX, VRTX M520, VRTX M620
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
