Product
Dell Advanced E-Port II with 130w AC Adapter
Quicklinx: 8G2DWS00 Mfr#: 452-11421
Maximize your workspace with the Dell E-Port Plus Replicator. This E-Port Plus Replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices. It also gives you ease of mobility wherein you need not unplug and re-plug multiple peripherals to access your printer or other devices.
Dell E-Port II Advanced - port replicator
Port replicator
28.8 cm x 17 cm x 5.37 cm
1.05 kg
United Kingdom, Ireland
Power adapter - external 130 Watt
Latitude 6430u, E5250, E5270, E5420, E5420m, E5430, E5440, E5450, E5470, E5520, E5520m, E5530, E5540, E5550, E5570, E6230, E6320, E6330, E6420, E6430, E6430S, E6440, E6520, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
Port replicator
28.8 cm
17 cm
5.37 cm
1.05 kg
1 x headphones - output - mini-phone 3.5 mm , 1 x microphone - input - mini-phone 3.5 mm , 1 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x USB 2.0 - 4 pin USB Type A , 2 x display / video - DVI-Digital - 24+1 pin digital DVI , 1 x network - Ethernet - RJ-45 , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x display / video - VGA - 15 pin D-Sub (DB-15) , 1 x serial - 9 pin D-Sub (DB-9) , 1 x parallel - 25 pin D-Sub (DB-25) , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 2 x display / video - DisplayPort - 20 pin DisplayPort
Power Provided
130 Watt
Dell Latitude 6430u, E5250, E5270, E5420, E5420 N-Series, E5420m, E5430, E5440, E5450, E5470, E5520, E5520 BRC 6, E5520 N-Series, E5520m, E5530, E5540, E5550, E5570, E6230, E6320, E6320 N-Series, E6330, E6420, E6420 ATG, E6420 N-Series, E6420 XFR, E6430, E6430 ATG, E6430S, E6440, E6520, E6520 N-Series, E6530, E6540, E7240, E7250, E7270, E7440, E7450, E7470
8G2D C2G HDMI to DisplayPort Adapter Converter In Stock £37.46
8G2D C2G 2m DisplayPort Male to HD Male Adapter Cable - Black In Stock £22.65
8G2D C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable In Stock £24.72
8G2D C2G 3m DisplayPort Cable with Latches M/M - Black In Stock £8.17
8G2D C2G 10m DisplayPort Cable with Latches M/M – Black In Stock £23.32
8G2D C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black In Stock £16.20
8G2D C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black In Stock £20.75
8G2D C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black In Stock £15.89
