Maximize your workspace with the Dell E-Port Plus replicator. This E-Port Plus replicator gives you a comfortable work space where you can plug a keyboard, mouse and monitor to the port replicators and use your laptop like a desktop! Simplified connectivity facilitates a single interface to connect to your printer, monitor or other peripheral devices. It also gives you ease of mobility wherein you need not unplug and re-plug multiple peripherals to access your printer or other devices.
- Dell Advanced E-Port II - port replicator
- Product Type
- Port replicator
- 28.8 cm x 5.37 cm x 17 cm
- 1.05 kg
- Localisation
- United Kingdom, Ireland
- Power
- Power adapter - external 240 Watt Power Provided
- Designed For
- Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
- Product Type
- Port replicator
- 28.8 cm
- 5.37 cm
- 17 cm
- 1.05 kg
- Localisation
- 1 x display / video - VGA - 15 pin HD D-Sub (HD-15) , 2 x display / video - DisplayPort - 20 pin DisplayPort , 2 x display / video - DVI-Digital - 24+1 pin digital DVI , 2 x serial - 9 pin D-Sub (DB-9) , 2 x parallel - 25 pin D-Sub (DB-25) , 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style) , 1 x mouse - generic - 6 pin mini-DIN (PS/2 style) , 1 x microphone - input - mini-phone 3.5 mm , 2 x SuperSpeed USB 3.0 - 9 pin USB Type A , 1 x eSATA / USB 2.0 - 11 pin USB/eSATA , 2 x USB 2.0 - 4 pin USB Type A , 1 x network - Ethernet - RJ-45 , 1 x headphones - output - mini-phone stereo 3.5 mm , 1 x docking / port replicator
- Power Device
- Power Provided
- 240 Watt
- Designed For
- Dell Precision 3510, 7510, 7710, M2800, M4600, M4700, M4800, M6600, M6700, M6800
C2G 3m DisplayPort Cable with Latches M/M - Black | In Stock | £12.92 |
