The Dell AC511 Stereo USB Sound Bar offers users a low profile, stylish sound solution that matches the styling of various monitors with convenient USB power. Also, the headphone jack that allows users to enjoy audio from their favorite games, music and movies, without sacrificing valuable desk space. Moreover, the USB-powered device makes it easy to use your speaker through your USB port, eliminating the need for batteries or a power cord. You can simply plug in the speaker to an open USB port in your computer and get started using the drive without the need to install any software. It provides high performance quality sound so you'll be able to enjoy your speakers as soon as you plug it in and start using it.
Low-profile design
Until you hear it, you'll hardly notice it's there. The Dell USB Soundbar can give you the sound you want without big speakers and long cables. Compatible with different monitors, it's quickly installed and hardly noticeable - at least to the eye. -
Rich stereo sound
The sound belies its size. Your music comes through crisp and clear. Games and movies are a completely unseen experience. For private listening, the Dell USB Soundbar also includes a convenient headphone jack. -
USB powered
The Dell USB Soundbar is simplicity itself. No extra software. No power cord. No batteries. Just plug into an available USB port and enjoy the rich stereo sound.
- Dell AC511 - sound bar - for PC
- Product Type
- Sound bar - for PC
- Speaker Type
- Active
- Continuous Power
- 2.5 Watt
- Frequency Response
- 100 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 1 x sound bar 2.5 Watt - 100 - 20000 Hz
- Speaker Details
- Sound bar - stereo x 2
- Power Options
- USB powered
- 40.6 cm x 3.9 cm x 4.9 cm
- 454 g
- 1-year warranty
- Product Type
Speaker System
- Speaker Type
- Active
- Continuous Power
- 2.5 Watt
- 100 - 20000 Hz
- Amplifier
- Integrated
- Recommended Placing
- Under-the-monitor
- Controls
- Volume
- Speakers Included
- 1 x sound bar - 2.5 Watt - 100 - 20000 Hz - wired
- Speaker Details
- Connector Type
- Headphones (mini-phone stereo 3.5 mm) , Audio line-in (mini-phone stereo 3.5 mm)
- Included Accessories
- USB cable
- Power Source
- AC power adapter
- Options
- USB powered
- 40.6 cm
- 3.9 cm
- 4.9 cm
- 454 g
- Limited warranty - 1 year
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
