Dell 8GB Certified Memory Module - 2RX8 SODIMM 2400 MHz
Quicklinx: CWYDWS00 Mfr#: A9210967
Type: DDR4 SDRAM
Capacity: 8GB
Connection: SO-DIMM 260-pin
Speed: 2400MHz
Data Integrity: Non-ECC
17 in stock
£62.48 ex VAT
£74.97 inc VAT
Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
Dell - DDR4 - 8 GB - SO-DIMM 260-pin - unbuffered
RAM memory
8 GB
Memory Type
DDR4 SDRAM - SO-DIMM 260-pin
Upgrade Type
System specific
Data Integrity Check
Non-ECC
Speed
2400 MHz (PC4-19200)
Single rank, unbuffered
Voltage
1.2 V
DELL A9210967, DELL SNPMKYF9C/8G
Inspiron 3185, 7375, 7460, 3567, 3573, 5565, 5566, 5567, 5576, 5577, 7560, 7569, 7579, 7566, 5767, 3064, 7775, 5570, 5575, 5675, 5775; Latitude 3379, 3380, 3390, 3480, 3490, 3580, 3590, 5280, 5480, 5580, 5590, 7280, 7390, 7480, 7490; OptiPlex 3050, 5050, 5250, 7050, 7450; Precision X520, 5720, 7720
8 GB
Upgrade Type
System specific
DRAM
DDR4 SDRAM
SO-DIMM 260-pin
Speed
Non-ECC
Chips Organization
X8
Voltage
1.2 V
Alienware 13 R3, 15 R3, 17 R4 , Dell Inspiron 11 3185 2-in-1, 13 7375 2-in-1, 14 7460, 15 3567, 15 3573, 15 5565, 15 5566, 15 5567, 15 5576 Gaming, 15 5577 Gaming, 15 7560, 15 7569 2-in-1, 15 7579 2-in-1, 15 Gaming 7566, 17 5767, 20 3064, 27 7775, 5570, 5575, 5675, 5775 , Dell Latitude 13 3379 2-in-1, 13 3380, 3390 2-in-1, 3480, 3490, 3580, 3590, 5280, 5480, 5580, 5590, 7280, 7390, 7480, 7490 , Dell OptiPlex 3050, 5050, 5250 All In One, 7050, 7450 , Dell Precision 5720 AIO , Dell Precision Mobile Workstation 3520, 5520, 7520, 7720 , Dell Vostro 15 5568 , Dell XPS 15 9560
Type: DDR4 SDRAM
Capacity: 8GB
Speed: 2400MHz
Registered/Buffered: Unbuffered
Standard: PC4-19200
Brand: Dell
Price Range Ex VAT: 50 - 100
