Dell 7700 DLP FullHD 5000 Lumens Projector
Quicklinx: 973VWS00 Mfr#: 210-39508
Amaze your audience with Full 1080p HD. The Dell 7700FullHD projector can deliver stunning, ultra-bright multimedia presentations in almost any lighting condition.
  • Employ network management control
    Crestron RoomView compatibility and an RJ45 connection enable remote real-time facility-wide monitoring, control and reporting of vital information such as power status, lamp life and system alerts.
  • Go AV-cable free
    Opt for advanced features that include wireless audio and 720p video file streaming. Connect the 7700FullHD Projector with up to 30 users simultaneously using multi-PC session and share content from up to four presenters at the same time with 4-in-1 split-screen capability.
  • Discover outstanding connectivity
    Present multimedia from a range of devices with a multitude of ports, including dual HDMI, dual VGA-In, S-Video, composite video and component video.
  • Take control
    Operate your 7700FullHD projector from a distance using the full-featured remote control and on-screen menu.
  • Easy-to-change lamp
    The easily accessible lamp on the 7700FullHD is designed to last up to 1,500 hours3 in normal mode and up to 2,000 hours3 in eco-mode.
  • No filter to replace
    Enjoy simplified maintenance thanks to the filter-free design.
Dell 7700 - DLP projector - LAN
DLP projector - 1080p
Built-in Devices
Stereo speakers
Brightness
5000 lumens
Contrast Ratio
2500:1 / 10000:1 (dynamic)
Resolution
Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
1.07 billion colours
Bulb type
400 Watt
Bulb life cycle
Up to 1500 hour(s) - normal mode , Up to 2000 hour(s) - economic mode
Video Input
RGB, S-Video, composite video, component video (NTSC, PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, PAL 60, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G, M-NTSC), LAN
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
525 Watt
43.2 cm x 29 cm x 13.5 cm
7.3 kg
Built-in Devices
Stereo speakers
Projector
Brightness
5000 lumens
Contrast Ratio
Image Size
53 cm - 744 cm
Projection Distance
1 m - 12 m
Throw Ratio
1.85 - 2.22:1
Uniformity
85 %
Resolution
Full HD - Full HD (1920 x 1080)
Native Aspect Ratio
16:9
Colour Support
Bulb type
400 Watt
Bulb life cycle
High-bandwidth Digital Content Protection System (HDCP), BrilliantColor
Lens
Focus Type
Manual
Lens Aperture
F/2.6-2.9
Zoom Type
Manual
Zoom Factor
1.2x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-30 / +30
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, component video, composite video, S-Video
Video Modes
LAN and Wireless Image Transferring Protocols
Wired LAN
Speakers
Integrated
Output Power / Channel
5 Watt
Input Device
External
1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x VGA / component video input - 15 pin D-Sub (DB-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin D-Sub (DB-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x component video input - RCA x 3 , 1 x serial RS-232 - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x management - 4 pin mini-USB Type B , 2 x USB - 4 pin USB Type A , 1 x USB - 4 pin USB Type B
Wireless remote control
1 x VGA cable , 1 x USB cable
Security Features
Security lock slot (cable lock sold separately), password protection
525 Watt
Power Consumption Operational (Standby)
0.5 Watt
43.2 cm
29 cm
13.5 cm
7.3 kg
Limited warranty - 2 years - response time: next business day
5 °C
35 °C
Sound Emission
39 dBA
36 dBA
973V C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
