Always on the go? No more worries about running out of battery power! You can power your Laptop with this 6-Cell Lithium-Ion Battery from Dell. With a capacity of up to 65 WHr, the battery lets your laptop work seamlessly when you are on the move.
- Dell Primary Battery - Kit - laptop battery - 65 Wh
- Laptop battery
- 350 g
- Battery
- 6-cell - 65 Wh
- 26.58 cm x 4.58 cm x 3.395 cm
- 1-year warranty
- Designed For
- Latitude 3340
- Laptop battery
- Technology
- 6-cell
- Capacity
- 65 Wh
- Limited warranty - replacement - 1 year
- 26.58 cm
- 4.58 cm
- 3.395 cm
- 350 g
- Designed For
- Dell Latitude 3340
