Product
Dell 5130cdn Colour Laser Printer
Quicklinx: 7LXHWS00 Mfr#: 210-30611
Superb Performance
The Dell 5130cdn Color Laser Printer slashes printing and waiting time while delivering high-quality laser prints.
-Blazing Print Speeds: Dell 5130cdn delivers letter-sized pages at a speed of up to 47 ppm (pages per minute) in both mono and color. (Actual print speeds will vary with use.) Print duplex pages at up to 37.6 ppm (letter) in both mono and color. (Actual print speeds will vary with use.)
-Fast Warm-Up: The Dell 5130cdn delivers a first-print-out time (FPOT) as fast as 8.5 seconds in mono and 10 seconds in color.
-Excellent Print Quality: ColorbyDell technology incorporates an innovative print engine, advanced image-enhancement algorithm and advanced toner technology to deliver brilliant color printouts with crisp, clear text.
-Rich, Glossy Color Images: Advanced EA-Eco Toner emulsion aggregation process saturates paper with superfine toner particles for brilliant color reproduction
Dell 5130cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
60 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Print Speed
Up to 45 ppm - A4 (210 x 297 mm)
Max Resolution (B&W)
600 dpi
Max Resolution (Colour)
1200 dpi
Automatic Duplexing
Parallel, USB 2.0, Gigabit LAN, USB host
800 MHz
RAM Installed (Max)
256 MB (1.25 GB) - DDR2 SDRAM - SO-DIMM 144-pin
Language Simulation
PCL 5E, PostScript 3, PCL 6
Media Type
Envelopes, transparencies, labels, plain paper, cover paper, coated paper
Total Media Capacity
700 sheets
Monthly Duty Cycle (max)
110000 pages
Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, USB 2.0
Microsoft Certification
Compatible with Windows 7
1 year warranty
55.9 cm x 50.8 cm x 43.2 cm
Printer Type
Printer
Print Speed
Wired
600 dpi
1200 dpi
Automatic Duplexing
PostScript Support
Standard
Language Simulation
Fonts Included
81 x PCL , 136 x PostScript 3
800 MHz
RAM
RAM Installed (Max)
256 MB / 1.25 GB (max)
Technology / Form Factor
Slots Qty
1
Empty Slots
1
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
Media Sizes
ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), C5 (162 x 229 mm)
Envelope Sizes
Monarch (98.4 x 190.5 mm)
700 sheets
Media Feeders
1 x automatic - 150 sheets , 1 x automatic - 550 sheets
Max Media Capacity
2900 sheets
Output Trays Capacity
500 sheets
Duty Cycle
110000 pages
Print server
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x parallel - 36 PIN Centronics , 1 x USB host - 4 pin USB Type A
TAA Compliant
Environmental Standards
ENERGY STAR
Limited warranty - 1 year
55.9 cm
50.8 cm
43.2 cm
60 kg
Ink (9)
7LXH Dell 5130CDN BLACK IMAGE DRUM 50K P In Stock £81.84
7LXH Dell 5130CDN CYAN IMAGING DRUM 50 In Stock £80.21
7LXH Dell 5130CDN MAGENTA IMAG DRUM 50K In Stock £80.21
7LXH Dell 5130CDN YELLOW IMAGE DRUM 50K In Stock £81.84
7LXH Dell 5130cdn High Capacity BLACK In Stock £140.37
7LXH Dell 5130cdn High Capacity CYAN In Stock £186.50
7LXH Dell 5130cdn High Capacity MAGENTA In Stock £186.50
7LXH Dell 5130cdn High Capacity YELLOW In Stock £186.50
7LXH Dell 5130cdn Waste Toner Container In Stock £26.07
Other bundles (4)
7LXH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £2.23
7LXH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.20
7LXH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £11.76
7LXH C2G 30m Cat6a Booted Shielded (SSTP) Network Patch Cable – Blue In Stock £45.82
