Supercharge your Dell system with a Dell Memory upgrade engineered, tested and customized for your system. Adding more memory revs to your system's engine and allows you to release its full potential when working with 3D imaging, multimedia, and other memory intensive applications.
- Dell - DDR3L - module - 4 GB - DIMM 240-pin - 1600 MHz / PC3L-12800 - unbuffered
- Product Type
- Memory module
- Capacity
- 4 GB
- Memory Type
- DDR3L SDRAM - DIMM 240-pin
- Upgrade Type
- System specific
- Data Integrity Check
- ECC
- Speed
- 1600 MHz (PC3L-12800)
- Single rank, Low Voltage, unbuffered
- Voltage
- 1.35 V
- OEM Manufacturer Equivalent Part Number
- DELL A7303660
- Limited lifetime warranty
- Designed For
- PowerEdge C5220, C6105, C6145, M420, M520, M620, M915, R210 II, R220, R320, R410, R415, R420, R420xr, R515, R520, R610, R620, R715, R720, R720xd, R815, R920, T110 II, T20, T20 Mini Tower Server, T320, T420, T620; Precision T1650, T1700
- Capacity
- 4 GB
- Upgrade Type
- System specific
- DELL A7303660
- DRAM memory module
- Technology
- DDR3L SDRAM
- Form Factor
- DIMM 240-pin
- Speed
- ECC
- Chips Organization
- X8
- Voltage
- 1.35 V
- Compatible Slots
- 1 x memory - DIMM 240-pin
- Designed For
- Dell PowerEdge C5220, C6105, C6145, M420, M520, M620, M915, R210 II, R220, R320, R410, R415, R420, R420xr, R515, R520, R610, R620, R715, R720, R720xd, R815, R920, T110 II, T20, T20 Mini Tower Server, T320, T420, T620 , Dell Precision T1650, T1700
