Captivate your audience with the powerfully bright 4220 projector. Present bright, high-contrast graphics and multimedia, stream HD content, and enjoy outstanding versatility with optional wireless capabilities that allow you to easily connect multiple users.
Outstanding color and clarity
Bring your presentations to life with vibrant color, clear images and stereo sound. -
Versatile connectivity
Make your audience a part of the presentation with broad multi-user functionality. -
Advanced technology
Make good presentations great with outstanding image quality with DLP technology and BrilliantColor technology.
- Dell 4220 - DLP projector - portable - 3D - LAN
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
- Brightness
- 4100 lumens
- Contrast Ratio
- 2000:1
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Bulb type
- 300 Watt
- Bulb life cycle
- Up to 2000 hour(s) - normal mode , Up to 2500 hour(s) - economic mode
- Video Input
- S-Video, composite video, component video (NTSC), LAN
- Digital Video Standard
- High-Definition Multimedia Interface (HDMI)
- Video Modes
- 720p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50 - 60 Hz)
- 375 Watt
- 28.6 cm x 24.8 cm x 11 cm
- 2.9 kg
- DLP projector
- 3D Capable
- Built-in Devices
- Stereo speakers
Projector
- Brightness
- 4100 lumens
- Contrast Ratio
- 2000:1
- Image Size
- 78 cm - 780 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.6 - 1.92:1
- Uniformity
- 80 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Bulb type
- 300 Watt
- Bulb life cycle
- Controls & Adjustments
- Keystone correction
- High-bandwidth Digital Content Protection System (HDCP), BrilliantColor
Lens
- Lens Aperture
- F/2.4-2.66
- Keystone Correction Direction
- Vertical
- Vertical Keystone Correction
- -35 / +40
Video Input
- TV System
- NTSC
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video, S-Video
- Video Modes
- 720p
- LAN and Wireless Image Transferring Protocols
- Wired LAN
Speakers
- Integrated
- Sound Output Mode
- Stereo
- Output Power / Channel
- 5 Watt
- Speakers
- 2 x right / left channel
Input Device
- External
- 1 x composite video input - RCA , 1 x S-video input - 4 pin mini-DIN , 2 x VGA / component video input - 15 pin D-Sub (DB-15) , 2 x audio line-in - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin D-Sub (DB-15) , 1 x HDMI input , 1 x USB - mini-USB Type B (management) , 1 x serial RS-232 - 6 pin mini-DIN (PS/2 style) (management) , 1 x network - RJ-45 , 1 x audio line-in - RCA x 2 , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - 4 pin USB Type B , 1 x USB - 4 pin USB Type A
- Included Accessories
- Remote control
- Security Features
- Security lock slot (cable lock sold separately), password protection
- Voltage Required
- 375 Watt
- Power Consumption Operational (Standby)
- 0.5 Watt
- 28.6 cm
- 24.8 cm
- 11 cm
- 2.9 kg
- 5 °C
- 35 °C
- 0 - 80%
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
