Dell 22 Monitor P2217H 21.5" Black
Quicklinx: CF1KWS00 Mfr#: 210-AJED
The Dell 22 Monitor , P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
Dell P2217H - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
19 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
49.9 cm x 18 cm x 35.4 cm
5.36 kg
Environmental Standards
ENERGY STAR Qualified
Display Type
Energy Class
Class A+
19 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
49.9 cm x 18 cm x 35.4 cm - with stand
5.36 kg
HDMI , DisplayPort , VGA , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
Power Consumption (Typical)
17 Watt
Power Consumption Stand by
0.3 Watt
Sustainability Information
ENERGY STAR Certified
