The Dell 22 Monitor , P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
- Dell P2217H - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Energy Consumption per Year
- 19 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 49.9 cm x 18 cm x 35.4 cm
- 5.36 kg
- Environmental Standards
- ENERGY STAR Qualified
- Display Type
- Energy Class
- Class A+
- 19 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- LED backlight
- Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
- Black
- 49.9 cm x 18 cm x 35.4 cm - with stand
- 5.36 kg
- HDMI , DisplayPort , VGA , 2 x USB 3.0 , 2 x USB 2.0
Mechanical
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
Sustainability Information
- ENERGY STAR Certified
