Dell 22" Monitor P2217H Black VGA HDMI
Quicklinx: CF92WS00 Mfr#: P2217H
Diagonal Size: 22in
Max Resolution: 1920 x 1080
Response Time: 6ms
Interfaces: DisplayPort, HDMI, VGA (HD-15)
£106.24 ex VAT
£127.48 inc VAT
The Dell 22 Monitor | P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
Dell P2217H - without stand - LED monitor - Full HD (1080p) - 22"
LED-backlit LCD monitor - 22"
Energy Class
Class A+
Energy Consumption per Year
48.5 kWh
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1 / 4000000:1 (dynamic)
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Screen Coating
Anti-glare, 3H Hard Coating
49.89 cm x 5.03 cm x 29.73 cm
2.81 kg
Environmental Standards
ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, TCO Displays, EDID compatible
Display Type
Energy Class
Class A+
48.5 kWh
Diagonal Size
22"
Viewable Size
21.5"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.248 mm
Pixel Per Inch
102
Brightness
250 cd/m²
Contrast Ratio
Colour Support
Response Time
6 ms (grey-to-grey)
Vertical Refresh Rate
56 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
WLED
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% NTSC (CIE 1931) colour gamut, stand lock, 82% NTSC (CIE 1976) colour gamut, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, Dell ComfortView
49.89 cm x 5.03 cm x 29.73 cm - without stand
2.81 kg
HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots, arsenic free
1 x VGA cable - VGA to VGA , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
Mounting Kit
Optional
Security Slot Type
Kensington security slot
17 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption Sleep
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Display drivers, Dell Display Manager
ENERGY STAR Certified
10 - 80% (non-condensing)
Dell 22 Bundle deal on Dell 22" Monitor P2217H Black VGA HDMI
£205.41
CF92 StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount In Stock £109.46
CF92 StarTech.com Dual Monitor Stand In Stock £69.36
CF92 StarTech.com Cubicle Monitor Hanger In Stock £45.29
CF92 StarTech.com TV/Monitor Arm - Wallmount In Stock £50.91
Diagonal Size: 22in
Response Time: 6ms
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Dell
Price Range Ex VAT: 100 - 150
