The Dell 22 Monitor , P2217H brings a whole new level of productivity to the work place without sacrificing comfort and convenience.
- Dell P2217H - without stand - LED monitor - Full HD (1080p) - 22"
- LED-backlit LCD monitor - 22"
- Energy Class
- Class A+
- Energy Consumption per Year
- 48.5 kWh
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.248 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1 / 4000000:1 (dynamic)
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Colour Gamut
- 72% NTSC (CIE 1931), 82% NTSC (CIE 1976)
- Input Connectors
- HDMI, VGA, DisplayPort
- Screen Coating
- Anti-glare, 3H Hard Coating
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- Dimensions (WxDxH) - without stand
- 49.89 cm x 5.03 cm x 29.73 cm
- 2.81 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Plug and Play, DDC/CI, RoHS, EDID compatible
- Display Type
- Energy Class
- Class A+
- 48.5 kWh
- Diagonal Size
- 22"
- Viewable Size
- 21.5"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.248 mm
- Pixel Per Inch
- 102
- Brightness
- 250 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
- 56 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Backlight Technology
- WLED
- OSD Languages
- Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
- Stand lock, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Energy Gauge, Mercury free, Transition Minimised Differential Signaling (TMDS) technology, Dell ComfortView
- Black
- 49.89 cm x 5.03 cm x 29.73 cm - without stand
- 2.81 kg
- HDMI , DisplayPort , VGA , USB 3.0 upstream (Type B) , 2 x USB 2.0 downstream (Type A) , 2 x USB 3.0 downstream (Type A)
Mechanical
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), LED indicator, integrated cable management, VESA interface support, Dell Soundbar mounting slots, arsenic free
- Cables Included
- 1 x VGA cable - VGA to VGA , 1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable - USB Type A to B
- Mounting Kit
- Optional
- Security Slot Type
- Kensington security slot
- Input Voltage
- Power Consumption (Typical)
- 17 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- Included Software
- Display drivers, Dell Display Manager
Sustainability Information
- TCO Certified
- ENERGY STAR Certified
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
StarTech.com Dual Monitor Mount - Articulating Arms - Grommet or Desk Mount | In Stock | £143.78 |
StarTech.com Articulating Monitor Arm | In Stock | £132.69 |
StarTech.com Dual Monitor Stand | In Stock | £91.06 |
StarTech.com TV/Monitor Arm - Wallmount | In Stock | £82.52 |
