Get more productive than ever. Dell 19 monitor P1917S brings greater productivity to the workplace with added user comfort and convenience.
A more seamless workflow
Slim borders create a smoother and less obstructed visual experience when working across multiple monitors. -
Versatility you can count on
Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference. -
More ways to stay connected
Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices. -
Enhanced viewing experience
The Dell 19 monitor P1917S is perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue. -
Complete clarity
Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high 4000000:1 dynamic contrast ratio. -
Work comfortably with less stress
Dell's ComfortView feature helps to reduce harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled. -
Auto mode and PowerNap
Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer. -
Reliable and responsible
Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
- Dell P1917S - LED monitor - 19"
- LED-backlit LCD monitor - 19"
- Power Consumption (On mode)
- 11 W
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- 1280 x 1024 at 60 Hz
- Pixel Pitch
- 0.293 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Response Time
- 6 ms (grey-to-grey)
- Colour Support
- 16.7 million colours
- Input Connectors
- HDMI, VGA, DisplayPort
- Height, pivot (rotation), swivel, tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 40.6 cm x 18 cm x 36.9 cm
- 5.13 kg
- Environmental Standards
- TCO Certified Displays 8, ENERGY STAR Qualified
- Designed For
- Latitude 7400 2-in-1
- Display Type
- Diagonal Size
- 19"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- IPS
- Aspect Ratio
- 5:4
- Native Resolution
- Pixel Pitch
- 0.293 mm
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
- Black
- 40.6 cm x 18 cm x 36.9 cm - with stand
- 5.13 kg
- HDMI , DisplayPort , VGA , USB 3.0 , USB 2.0
Mechanical
- Cables Included
- 1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 11 W
- Power Consumption (Typical)
- 14 Watt
- Power Consumption Stand by
- 0.3 Watt
- TCO Certified
- ENERGY STAR Certified
- Designed For
- Dell Latitude 7400 2-in-1
