Dell 19" TFT Monitor 16x9 IPS Black
Quicklinx: CST5WS00 Mfr#: P1917S
Diagonal Size: 19in
Max Resolution: 1280 x 1024
Response Time: 6ms
Interfaces: DisplayPort, VGA (HD-15), HDMI
More than 50 in stock
£147.56 ex VAT
£177.07 inc VAT
Get more productive than ever. Dell 19 monitor P1917S brings greater productivity to the workplace with added user comfort and convenience.
  • A more seamless workflow
    Slim borders create a smoother and less obstructed visual experience when working across multiple monitors.
  • Versatility you can count on
    Enjoy full adjustability to pivot, tilt, adjust the height, and swivel your monitor to your exact preference.
  • More ways to stay connected
    Multiple connectivity ports on the bottom and side of the monitor allow you to easily connect to various devices.
  • Enhanced viewing experience
    The Dell 19 monitor P1917S is perfect for professionals who work long hours and depend on a monitor that will display stunning visuals without inducing eye fatigue.
  • Complete clarity
    Get excellent picture quality with consistent color representation across an ultrawide viewing angle and a high 4000000:1 dynamic contrast ratio.
  • Work comfortably with less stress
    Dell's ComfortView feature helps to reduce harmful blue light emission onscreen and with direct current, a flicker-free viewing experience is enabled.
  • Auto mode and PowerNap
    Color settings of your applications are now customizable and allow for presets. And with PowerNap, you can worry less about wasting energy when you're away from your computer.
  • Reliable and responsible
    Enjoy peace of mind with Dell services and eco-conscious features designed to keep you moving forward.
Dell P1917S - LED monitor - 19"
LED-backlit LCD monitor - 19"
Energy Class
Class D
Power Consumption (On mode)
11 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
1280 x 1024 at 60 Hz
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
6 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Voltage
40.6 cm x 18 cm x 36.9 cm
5.13 kg
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Latitude 7400 2-in-1
Display Type
Energy Class
Class D
Diagonal Size
19"
Viewable Size
19"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
5:4
Native Resolution
Pixel Pitch
0.293 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
6 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
LED backlight
Ultra wide viewing angle, Flicker Free technology, Premium Panel Guarantee, Dell ComfortView
40.6 cm x 18 cm x 36.9 cm - with stand
5.13 kg
HDMI , DisplayPort , VGA , USB 3.0 , USB 2.0
Mechanical
1 x VGA cable , 1 x DisplayPort cable , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
11 W
11 kWh/1000h
Power Consumption (Typical)
14 Watt
Power Consumption Stand by
0.3 Watt
TCO Certified
ENERGY STAR Certified
Dell Latitude 7400 2-in-1
Diagonal Size: 19in
Response Time: 6ms
Interfaces: VGA (HD-15)
Interfaces: HDMI
Brand: Dell
Stock Status: In stock
