Dell 1610HD WXGA DLP 3500 Lumens Projector
Quicklinx: 973KWS00 Mfr#: 210-30974
Whether you are presenting your ideas in a boardroom or in a classroom, the Dell 1610HD projector displays graphics and text in bright, high-contrast detail that helps you get your points across. Make effective lights-on presentations a reality with its 3500 lumens brightness and a maximum projection size of 362 inches at 10 meters (projector to screen distance) that display your ideas on a grand scale. To go a step ahead its contrast ratio of 2100:1 typical (full on/full off) and 1280 x 800 WXGA native resolution ensures you enjoy excellent visuals with rich, sharp image quality, deep colors, and easy-to-read text as well as its stunning details and depth.
With 8-watt built-in speakers, this projector will further enhance your presentations with superb audio quality. Designed to fit snugly into the palm of your hand, the infra red remote control makes it easy to perform page up and down. Packed with these and many more impressive features, this 1610HD projector delivers powerful presentation with great performance and flexibility.
Dell 1610HD - DLP projector - portable - 3D
DLP projector
3D Capable
Built-in Devices
Speaker
Brightness
3000 lumens
Contrast Ratio
2100:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
16.7 million colours
Bulb type
220 Watt
Video Input
RGB, S-Video, composite video, component video
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Output
RGB
Speakers
Speaker(s) - integrated
29.7 cm x 20.2 cm x 8.8 cm
2.4 kg
DLP projector
3D Capable
Built-in Devices
Speaker
Projector
Brightness
3000 lumens
Contrast Ratio
2100:1
Projection Distance
1.2 m - 10 m
Uniformity
85 %
Resolution
WXGA - WXGA (1280 x 800)
Native Aspect Ratio
16:10
Colour Support
Bulb type
220 Watt
Lens
Zoom Type
Manual
Zoom Factor
1.2x
Video Input
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
8 Watt
Speakers
1 x mixed channel
Input Device
External
2 x VGA / component video input - 15 pin HD D-Sub (HD-15) , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x microphone - mini-phone stereo 3.5 mm , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x USB - 4 pin USB Type B (management) , 1 x serial RS-232 - 6 pin mini-DIN (PS/2 style) (management) , 1 x network - RJ-45 (management)
Wireless remote control
1 x VGA cable
Security Features
Security lock slot (cable lock sold separately), password protection
29.7 cm
20.2 cm
8.8 cm
2.4 kg
973K C2G 5m USB 2.0 A/B Cable - Black In Stock £5.09
