Dell 1550 3800 ANSI lumens DLP XGA (1024x768) 3D Capable Projector
Quicklinx: CMPDWS00 Mfr#: 210-AIRN
Impressive views. Impactful presentations. A high-brightness XGA projector with easy set-up and fast source switching for multi-user collaboration.
  • Light up the room
    The Dell 1550 projector provides high-quality XGA projections with 3800 lumens, so your presentations are crisp and bright, even in poorly lit settings.
  • Communicate clearly
    The 4:3 aspect ratio and extremely large screen size up to 307.5", gives you clear images and easy, amplified big-screen collaboration.
  • Add another dimension
    The 1550 projector supports 3D projections: just add 3D glasses and you can take your presentation to the next dimension.
  • Easy to connect and manage
    Perfect for schools and organizations that need an everyday, workhorse projector, the 1550 allows for numerous means of connecting so collaboration is simple and streamlined.
  • Switch it up
    Multiple ports make it easy to connect to almost any device and switch back and forth between multiple users.
  • Manage and share
    Wired network control makes it easy to manage multiple meeting rooms.
Dell 1550 - DLP projector - 3D
DLP projector
3D Capable
Yes (3D glasses sold separately)
Microdisplay
DarkChip 3
Brightness
3800 ANSI lumens
Contrast Ratio
2200:1 / 10000:1 (dynamic)
Resolution
XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
1.07 billion colours
Bulb type
260 Watt
Bulb life cycle
Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
Video Input
RGB, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
Video Modes
480p, 720p, 1080i, 1080p, 480i, 576i, 576p
Speakers
Speaker(s) - integrated
315 Watt
32 cm x 25 cm x 9.5 cm
3.5 kg
DLP projector
3D Capable
Projector
Microdisplay
DarkChip 3
Brightness
3800 ANSI lumens
Contrast Ratio
Image Size
78 cm - 781 cm
Projection Distance
1.2 m - 10 m
Throw Ratio
1.6 - 1.92:1
Uniformity
85 %
Resolution
XGA - XGA (1024 x 768)
Native Aspect Ratio
4:3
Colour Support
Bulb type
260 Watt
Bulb life cycle
2x colour wheel
Lens
Lens Aperture
F/2.4-2.66
Zoom Type
Manual
Zoom Factor
1.2x
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video
Video Modes
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
2 x AAA batteries, wireless remote control
1 x VGA cable - VGA to VGA
Security Features
Power Source
AC
315 Watt
Power Consumption Stand by
0.5 Watt
Software Included
Drivers & Utilities
32 cm
25 cm
9.5 cm
3.5 kg
5 °C
Sound Emission
37 dB
32 dB
