Impressive views. Impactful presentations. A high-brightness XGA projector with easy set-up and fast source switching for multi-user collaboration.
Light up the room
The Dell 1550 projector provides high-quality XGA projections with 3800 lumens, so your presentations are crisp and bright, even in poorly lit settings. -
Communicate clearly
The 4:3 aspect ratio and extremely large screen size up to 307.5", gives you clear images and easy, amplified big-screen collaboration. -
Add another dimension
The 1550 projector supports 3D projections: just add 3D glasses and you can take your presentation to the next dimension. -
Easy to connect and manage
Perfect for schools and organizations that need an everyday, workhorse projector, the 1550 allows for numerous means of connecting so collaboration is simple and streamlined. -
Switch it up
Multiple ports make it easy to connect to almost any device and switch back and forth between multiple users. -
Manage and share
Wired network control makes it easy to manage multiple meeting rooms.
- Dell 1550 - DLP projector - 3D
- DLP projector
- 3D Capable
- Yes (3D glasses sold separately)
- Microdisplay
- DarkChip 3
- Brightness
- 3800 ANSI lumens
- Contrast Ratio
- 2200:1 / 10000:1 (dynamic)
- Resolution
- XGA (1024 x 768)
- Native Aspect Ratio
- 4:3
- Colour Support
- 1.07 billion colours
- Bulb type
- 260 Watt
- Bulb life cycle
- Up to 3000 hour(s) - normal mode , Up to 5000 hour(s) - economic mode
- Video Input
- RGB, component video (PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G)
- Video Modes
- 480p, 720p, 1080i, 1080p, 480i, 576i, 576p
- Speakers
- Speaker(s) - integrated
- Power
- AC 120/230 V (50/60 Hz)
- 315 Watt
- 32 cm x 25 cm x 9.5 cm
- 3.5 kg
- DLP projector
- 3D Capable
Projector
- Microdisplay
- DarkChip 3
- Brightness
- 3800 ANSI lumens
- Contrast Ratio
- Image Size
- 78 cm - 781 cm
- Projection Distance
- 1.2 m - 10 m
- Throw Ratio
- 1.6 - 1.92:1
- Uniformity
- 85 %
- Resolution
- XGA - XGA (1024 x 768)
- 4:3
- Colour Support
- Bulb type
- 260 Watt
- Bulb life cycle
- 2x colour wheel
Lens
- Lens Aperture
- F/2.4-2.66
- Zoom Type
- Manual
- Zoom Factor
- 1.2x
Video Input
- TV System
- PAL-B/G, PAL-N, PAL-M, PAL-I, NTSC 4.43, NTSC 3.58, PAL-D, SECAM L, PAL-H, SECAM K1, SECAM D/K, SECAM B/G
- Analogue video Signal
- Video Interfaces
- VGA, HDMI, composite video
- Video Modes
Speakers
- Integrated
- Sound Output Mode
- Mono
- Output Power / Channel
- 10 Watt
- Speakers
- 1 x mixed channel
- 1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 2 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x USB - mini-USB Type B , 1 x USB - 4 pin USB Type A , 1 x serial RS-232 - 9 pin D-Sub (DB-9) , 1 x network - RJ-45
- Included Accessories
- 2 x AAA batteries, wireless remote control
- Cables Included
- 1 x VGA cable - VGA to VGA
- Security Features
- Power Source
- AC
- Voltage Required
- 315 Watt
- Power Consumption Stand by
- 0.5 Watt
- Software Included
- Drivers & Utilities
- 32 cm
- 25 cm
- 9.5 cm
- 3.5 kg
- 5 °C
- 40 °C
- Sound Emission
- 37 dB
- Sound Emission (Economic Mode)
- 32 dB
