Your basket is empty
Dell 1.2TB 10K RPM SAS 6Gbps 2.5in Hot-plug Hard Drive
Quicklinx: BGQ4WS00 Mfr#: 400-AEFQ
Increase the storage capacity of your Dell™ system with this 1.2 TB Hard Drive from Dell. It boasts a storage capacity of 1.2 TB, enabling users to store large amounts of data. This hard drive features a Serial Attached SCSI and it offers a maximum rotational speed of 10,000 RPM. This product has been tested and validated on Dell systems and is compatible with select Dell Systems. It is supported by Dell Technical Support when used with a Dell system.
Dell - hard drive - 1.2 TB - SAS 6Gb/s
Hard drive - hot-swap
1.2 TB
2.5"
SAS 6Gb/s
Spindle Speed
10000 rpm
PowerEdge R430 (2.5"), R630 (2.5"), R730 (2.5"), R730xd (2.5"), T430 (2.5"), T630 (2.5")
1.2 TB
2.5"
SAS 6Gb/s
Performance
Spindle Speed
10000 rpm
Expansion & Connectivity
1 x SAS 6Gb/s
Compatible Bay
2.5"
Dell PowerEdge R430 (2.5"), R630 (2.5"), R730 (2.5"), R730xd (2.5"), T430 (2.5"), T630 (2.5")
