Dell
24 Monitor P2419H - 60.5cm (23.8") Black UK 1920 x 1080
Dell 24 Monitor P2419H - 60.5cm (23.8") Black UK 1920 x 1080
Quicklinx: DTVYWS00 Mfr#: DELL-P2419H
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 5ms
Speakers: None
Interfaces: VGA (HD-15), DisplayPort, HDMI
More than 50 in stock
£168.64 ex VAT
£202.36 inc VAT
Standard delivery Delivered within 3-5 working days
Optimize your workspace with this efficient 23.8" monitor built with an ultrathin bezel design, a small footprint and comfort-enhancing features.
  • Expand your efficiency
    The three-sided ultrathin bezel design lets you enjoy an uninterrupted view of your content across multiple monitors. And, with dual monitors, you can increase your productivity.
  • More ways to multitask
    Work conveniently across multiple screens and select from predefined templates with the Easy Arrange feature on Dell Display Manager software. Quickly tile and arrange your applications and get back to work faster with Auto-restore, a feature that remembers where you left off.
  • Consistent and rich colors
    A wide viewing angle enabled by In-Plane Switching (IPS) technology lets you see vibrant colors - no matter where you sit.
  • Clean and clutter-free
    Focus on your work while hiding away cable clutter with an improved cable management design.
  • Easy on the eyes
    This monitor has a flicker-free screen with ComfortView, a feature that reduces harmful blue light emissions. It's designed to optimize eye comfort even over extended viewing.
  • Adjust to your comfort
    Pivot, tilt, swivel and adjust the height of your monitor for a comfortable setup all day long.
Dell P2419H - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class D
Energy Consumption per Year
29 kWh
Power Consumption (On mode)
13.9 W
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Brightness
250 cd/m²
Contrast Ratio
1000:1
Response Time
8 ms (normal); 5 ms (fast)
Colour Support
16.7 million colours
Input Connectors
HDMI, VGA, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare, 3H Hard Coating
Voltage
53.78 cm x 16.6 cm x 35.61 cm
Environmental Standards
TCO Certified Displays 8, ENERGY STAR Qualified
Plug and Play, DDC/CI, RoHS, EDID compatible, DisplayPort 1.2
3-year warranty
Bundled Services
3 years Advanced Exchange Service
Latitude 7400 2-in-1; XPS 13 9380, 15 9570
Display Type
Energy Class
Class D
29 kWh
Diagonal Size
24"
Viewable Size
23.8"
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.275 mm
Pixel Per Inch
92
Brightness
250 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
Vertical Refresh Rate
50 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Backlight Technology
LED backlight
OSD Languages
Chinese (simplified), Brazilian Portuguese, English, German, French, Russian, Spanish, Japanese
72% (CIE 1931) colour gamut, LED edgelight system, Dell Custom Color, Flicker Free technology, BFR/PVC-free, Mercury free, Dell ComfortView, arsenic free
53.78 cm x 16.6 cm x 35.61 cm - with stand
DisplayPort , VGA , HDMI , USB 3.0 upstream (Type B) , 2 x USB 3.0 downstream (Type A) , 2 x USB 2.0 downstream (Type A)
Mechanical
Tilt Angle
-5/+21
Swivel Angle
90
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), LED indicator, VESA interface support
1 x DisplayPort cable - DisplayPort to DisplayPort , 1 x SuperSpeed USB cable
Security Slot Type
Kensington security slot
Input Voltage
13.9 W
13.9 kWh/1000h
Power Consumption (Typical)
18 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Included Software
Microsoft Windows 7 / 8 / 8.1 / 10
Dimensions & Weight Details
Without stand - width: 53.78 cm - depth: 4.28 cm - height: 32.22 cm - weight: 3.26 kg , With stand - width: 53.78 cm - depth: 16.6 cm - height: 35.61 cm
Shipping Weight
7.1 kg
TCO Certified
ENERGY STAR Certified
Limited warranty - parts and labour - 3 years
Bundled Services
20 - 80% (non-condensing)
Dell Latitude 7400 2-in-1 , Dell XPS 13 9380, 15 9570
Used stock
What is used stock?
Accessories Packaging Functional Software Manuals
Ref: DTVY 044665
Condition: Customer return - item has been used and shows signs of use
This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is present and in good condition  This part of the stock item is not applicable e.g. it might not include accessories or software as standard  This part of the stock item is present and in good condition  £125.22
Legend
  • This part of the stock item is present and in good conditionThis part of the stock item is present and in good condition
  • This part of the stock item is not present or functionalThis part of the stock item is not present or functional
  • This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
  • This part of the stock item is not applicable e.g. it might not include accessories or software as standardThis part of the stock item is not applicable e.g. it might not include accessories or software as standard
  • This item has not been tested.This item has not been tested.
Diagonal Size: 24in
Response Time: 5ms
Speakers: None
Interfaces: DisplayPort
Interfaces: HDMI
Brand: Dell
Stock Status: In stock
Stock Status: Used Stock
