This rugged mobile computer is particularly suitable for mobile commerce solutions in the retail environment both on store shelves and in stock rooms. With the best ergonomics on the market, the Skorpio X3 mobile computer reduces operator fatigue with no compromise in terms of reliability and robustness, resisting harsh environments, multiple drops, strong shocks and repetitive tumbles. The pistol grip model has the most durable and comfortable handle in the industry. Its compact size and light weight combine to offer excellent balance and superior handling.
The Skorpio X3 mobile computer's wireless communication capabilities (Bluetooth EDR, IEEE 802.11 a/b/g) enable fast transactions and complete interaction with information systems including the newest RF security protocols such as WPA and WPA2. Additionally, Cisco Compatible Extensions CCX V4 certification permits all the advantages offered by the Cisco WLAN infrastructure.
Outstanding user interface
Equipped with the largest high-visibility color graphic display (3.2-inch) with touch screen in its class, the Skorpio X3 mobile computer helps users work more efficiently. Three different keyboards (the 50-key alphanumeric keypad, the 38-key functional keypad and the 28-key numeric keypad) allow data to be input very quickly. -
Ergonomic and reliable
This rugged mobile computer is particularly suitable for mobile commerce solutions in the retail environment both on store shelves and in stock rooms. With the best ergonomics on the market, the Skorpio X3 mobile computer reduces operator fatigue with no compromise in terms of reliability and robustness, resisting harsh environments, multiple drops, strong shocks and repetitive tumbles. The pistol grip model has the most durable and comfortable handle in the industry. Its compact size and light weight combine to offer excellent balance and superior handling. -
Wireless communication
The Skorpio X3 mobile computer's wireless communication capabilities (Bluetooth EDR, IEEE 802.11 a/b/g) enable fast transactions and complete interaction with information systems including the newest RF security protocols such as WPA and WPA2. Additionally, Cisco Compatible Extensions CCX V4 certification permits all the advantages offered by the Cisco WLAN infrastructure. -
Datalogic's patented 'Green Spot'
Skorpio X3 mobile computers also include Datalogic's patented 'Green Spot' technology for good-read feedback. This technology projects a green spot directly on the bar code, notifying the user that a successful 'read' has occurred. Both 1D laser scanning and 2D bar code imaging configurations provide an inclined scan engine so that the display can be viewed while reading bar codes. There is no need for the user to turn the wrist in order to scan, thus making it easier to aim and faster to read.
- Datalogic Skorpio X3 - data collection terminal - Win CE 6.0 - 512 MB - 3.2"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows CE 6.0
- Display
- 3.2" colour TFT - LED backlight - 240 x 320
- Processor
- Intel XScale PXA310
- Processor Clock Speed
- 624 MHz
- Storage
- 512 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSDHC
- Wireless Connectivity
- 802.11a/b/g, Bluetooth 2.0 EDR
- Barcode Reader
- Yes (2D imager)
- Barcodes
- QR code, MaxiCode, Aztec code, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, Japanese Post, Kix (Netherlands) Post, RM4SCC, Royal Mail
- USB host
- 7.6 cm x 15.6 cm x 19.3 cm
- 482 g
- 1-year warranty
- Product Type
- Operating System
Display
- 3.2" colour TFT (transflective) - LED backlight
- Resolution
- 240 x 320
- Processor
- 624 MHz
- Storage
- 512 MB
- RAM
- 256 MB
- microSDHC
- Max Supported Capacity
- 32 GB
Communications
- WPA, WPA2
Input Device
- Touch-screen, backlit keyboard
- Keys Qty
- 28
Barcodes
- Barcode Reader
- Scan Element Type
- 2D imager
- Barcodes
- Minimum Bar Width
- 4 mil
Software
- Preloaded Software
- Wavelink Terminal Emulation
Expansion and Connectivity
- Expansion Slots
- 1 x microSDHC
- 1 x Micro-USB , 1 x dock
- USB Host
- Installed Qty (Max Supported)
- 1
- Technology
- Lithium Ion
- Capacity
- 3000 mAh
- Water-resistant, Green Spot technology, drop-resistant, numeric pad
- Included Accessories
- Pistol grip handle
- Bluetooth Class 2, RoHS, IP64, IEC 60825-1, CCX V4, EN 60825-1
- 7.6 cm
- 15.6 cm
- 19.3 cm
- 482 g
- Limited warranty - 1 year
- -10 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
