Product
Datalogic Skorpio X3 Pistol grip 802.11 a/b/g CCX v4 Bluetooth v2
Quicklinx: B7XGWS00 Mfr#: 942400002
This rugged mobile computer is particularly suitable for mobile commerce solutions in the retail environment both on store shelves and in stock rooms. With the best ergonomics on the market, the Skorpio X3 mobile computer reduces operator fatigue with no compromise in terms of reliability and robustness, resisting harsh environments, multiple drops, strong shocks and repetitive tumbles. The pistol grip model has the most durable and comfortable handle in the industry. Its compact size and light weight combine to offer excellent balance and superior handling.
The Skorpio X3 mobile computer's wireless communication capabilities (Bluetooth EDR, IEEE 802.11 a/b/g) enable fast transactions and complete interaction with information systems including the newest RF security protocols such as WPA and WPA2. Additionally, Cisco Compatible Extensions CCX V4 certification permits all the advantages offered by the Cisco WLAN infrastructure.
  • Outstanding user interface
    Equipped with the largest high-visibility color graphic display (3.2-inch) with touch screen in its class, the Skorpio X3 mobile computer helps users work more efficiently. Three different keyboards (the 50-key alphanumeric keypad, the 38-key functional keypad and the 28-key numeric keypad) allow data to be input very quickly.
  • Ergonomic and reliable
  • Wireless communication
  • Datalogic's patented 'Green Spot'
    Skorpio X3 mobile computers also include Datalogic's patented 'Green Spot' technology for good-read feedback. This technology projects a green spot directly on the bar code, notifying the user that a successful 'read' has occurred. Both 1D laser scanning and 2D bar code imaging configurations provide an inclined scan engine so that the display can be viewed while reading bar codes. There is no need for the user to turn the wrist in order to scan, thus making it easier to aim and faster to read.
Datalogic Skorpio X3 - data collection terminal - Win CE 6.0 - 512 MB - 3.2"
Data collection terminal - rugged
Operating System
Microsoft Windows CE 6.0
Display
3.2" colour TFT - LED backlight - 240 x 320
Intel XScale PXA310
Processor Clock Speed
624 MHz
Storage
512 MB integrated
RAM
256 MB
Supported Flash Memory Cards
microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.0 EDR
Barcode Reader
Yes (visible laser diode)
Barcodes
Pharmacode 39, Code 93, Code 39, GS1 DataBar, EAN/JAN-13, Code 128, Code 11, Code 2 of 5, UPC, MSI-Plessey, Trioptic Code
7.6 cm x 4.2 cm x 19.3 cm
482 g
1 year warranty
Operating System
Display
3.2" colour TFT (transflective) - LED backlight
Resolution
240 x 320
Intel XScale PXA310
624 MHz
Storage
512 MB integrated
RAM
256 MB
microSDHC
Max Supported Capacity
32 GB
Communications
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, backlit keyboard
Keys Qty
50
Barcodes
Barcode Reader
Scan Element Type
Visible laser diode
Light Source Wave Length
630-670 nm
Barcodes
Minimum Bar Width
4 mil
Expansion and Connectivity
Expansion Slots
1 x microSDHC
1 x Micro-USB , 1 x serial RS-232 , 1 x LAN (supporting via optional cradle)
Installed Qty (Max Supported)
1
Lithium Ion
3000 mAh
Water-resistant, dust-resistant, belt clip, rugged, Green Spot technology, drop-resistant
Pistol grip handle
EN55024, Bluetooth Class 2, EN55022 Class B, EN 300.328, EN 301.489.1, EN 301.489.17, RoHS, EN 60950-1, IP64, WEEE, EN 301.893, CCX V4, EN 60825-1 Class 2, EN 62311
7.6 cm
4.2 cm
19.3 cm
482 g
Limited warranty - 1 year
-10 °C
50 °C
0 - 95% (non-condensing)
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
