Product
Datalogic Skorpio X3 Hand held 802.11 a/b/g CCX v4 Bluetooth v2
Quicklinx: B7XHWS00 Mfr#: 942350032
This rugged mobile computer is particularly suitable for mobile commerce solutions in the retail environment both on store shelves and in stock rooms. With the best ergonomics on the market, the Skorpio X3 mobile computer reduces operator fatigue with no compromise in terms of reliability and robustness, resisting harsh environments, multiple drops, strong shocks and repetitive tumbles. The pistol grip model has the most durable and comfortable handle in the industry. Its compact size and light weight combine to offer excellent balance and superior handling.
The Skorpio X3 mobile computer's wireless communication capabilities (Bluetooth EDR, IEEE 802.11 a/b/g) enable fast transactions and complete interaction with information systems including the newest RF security protocols such as WPA and WPA2. Additionally, Cisco Compatible Extensions CCX V4 certification permits all the advantages offered by the Cisco WLAN infrastructure.
  • Outstanding user interface
    Equipped with the largest high-visibility color graphic display (3.2-inch) with touch screen in its class, the Skorpio X3 mobile computer helps users work more efficiently. Three different keyboards (the 50-key alphanumeric keypad, the 38-key functional keypad and the 28-key numeric keypad) allow data to be input very quickly.
  • Ergonomic and reliable
  • Wireless communication
  • Datalogic's patented 'Green Spot'
    Skorpio X3 mobile computers also include Datalogic's patented 'Green Spot' technology for good-read feedback. This technology projects a green spot directly on the bar code, notifying the user that a successful 'read' has occurred. Both 1D laser scanning and 2D bar code imaging configurations provide an inclined scan engine so that the display can be viewed while reading bar codes. There is no need for the user to turn the wrist in order to scan, thus making it easier to aim and faster to read.
Datalogic Skorpio X3 - data collection terminal - Win Embedded Handheld 6.5 - 512 MB - 3.2"
Data collection terminal - rugged
Operating System
Microsoft Windows Embedded Handheld 6.5
Display
3.2" colour TFT - LED backlight - 240 x 320
XScale PXA310
Processor Clock Speed
624 MHz
Storage
512 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.0 EDR
Barcode Reader
Yes (2D imager)
Barcodes
GS1 DataBar, QR code, MaxiCode, Aztec code, MicroPDF417, Postnet, PDF417, Data Matrix, PLANET, Australian Post, Japanese Post, Kix (Netherlands) Post, RM4SCC, Royal Mail, Intelligent Mail Barcode
USB host
7.6 cm x 4.2 cm x 19.3 cm
392 g
1 year warranty
Operating System
Display
3.2" colour TFT (transflective) - LED backlight
Resolution
240 x 320
XScale PXA310
624 MHz
Storage
512 MB
RAM
256 MB
microSD, microSDHC
Max Supported Capacity
32 GB
Communications
Security Protocols & Features
WPA, WPA2, CCXv4
Input Device
Touch-screen, backlit keyboard
Keys Qty
28
Barcodes
Barcode Reader
Scan Element Type
2D imager
Barcodes
Max Working Distance
41.5 cm
Minimum Bar Width
5 mil
Software
Preloaded Software
Microsoft Java Virtual Machine, Microsoft Internet Explorer 6.0, MCL, Microsoft Excel Mobile, Microsoft Word Mobile, Microsoft PowerPoint Mobile, Wavelink Avalanche, Microsoft OneNote Mobile, Wavelink Studio, Datalogic Mobility Developer Assistant, Wavelink Terminal Emulation, Datalogic Windows SDK, Wavelink Avalanche Remote Control, Wavelink Avalanche SecurePlus, Wavelink Certificate Manager, Microsoft Outlook
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x serial RS-232 , 1 x Micro-USB
USB Host
Lithium Ion
11.1 Wh
Green Spot technology, drop-resistant
Bluetooth Class 2, RoHS, IP64, IEC 60825-1, EN 60825-1, IEC 60529 IP64, EN 62471:2008, 21 CFR 1040.10, IEC 62471
7.6 cm
4.2 cm
19.3 cm
392 g
Limited warranty - 1 year
-10 °C
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
