The Datalogic Falcon X3 mobile computer takes the Falcon X3's industry leading pistol grip form to the next level of performance in ergonomics, computing and ease of use. The Falcon X3's Summit IEEE 802.11 a/b/g radio with CCX v4 certification from Cisco ensures seamless roaming in warehouse and logistics environments. Falcon X3 delivers rugged construction, laser and image data capture, along with real time communications in a product that is effortless to develop for, deploy and manage.
Real time data capture
Capture with a high performance laser scanner with green spot, an auto ranging laser (XLR) scanner, or a 2D imager with green spot combined with a 3-megapixel color camera. Communicate over a Summit 802.11 a/b/g radio with CCX v4 certification for security and seamless roaming or through wired standards including USB, RS232, modem and Ethernet. -
Ergonomic and rugged
Ergonomic hand held and pistol grip form factors balance a 3.5-inch display and full keyboards. Functional rubberized plastic enclosures survive daily abuse and trauma from drops to concrete and exposure to water and dust. Users feel the full shift difference of oversized numeric and alphanumeric back lit keyboards, a crystal clear display and an arched pistol grip handle with ergonomic trigger.
- Datalogic Falcon X3 - data collection terminal - Win CE 6.0 - 256 MB - 3.5"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows CE 6.0
- Display
- 3.5" colour TFT - 240 x 320
- Processor
- Intel XScale PXA310
- Processor Clock Speed
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11a/b/g, Bluetooth 2.0 EDR
- Barcode Reader
- Yes (laser)
- Barcodes
- Code 93, Code 39, UCC/EAN-128, ISBT 128, GS1 DataBar, Bookland, Code 32, Codabar, Code 128, Code 2 of 5, Postnet, MSI-Plessey, PLANET, Australian Post, Japanese Post, Kix (Netherlands) Post, UPC-A/EAN-13 with Extended Coupon Code, ISSN, Royal Mail
- 8.8 cm x 16.8 cm x 22.5 cm
- 0.7 kg
- Product Type
- Operating System
Display
- 3.5" colour TFT (transflective)
- Resolution
- 240 x 320
- Colour Depth
- 64K colours (16-bit)
- Processor
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB
Communications
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, stylus, navigation button, backlit keyboard
- Keys Qty
- 52
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
- Barcodes
- Max Working Distance
- 40 cm
- Minimum Bar Width
- 5 mil
Software
- Preloaded Software
- Microsoft Internet Explorer 6.0, Microsoft WordPad, Wavelink Avalanche, Wavelink Studio, Wavelink Terminal Emulation, Wavelink Industrial Browser
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x dock
- Technology
- Lithium Ion
- Capacity
- 5000 mAh
- Water-resistant, dust-resistant, Green Spot technology, drop-resistant
- Included Accessories
- Stylus, pistol grip handle
- TUV, Bluetooth Class 2, Laser Class 2, IP64, CCX V4
- 8.8 cm
- 16.8 cm
- 22.5 cm
- 0.7 kg
- -20 °C
- 50 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
