Datalogic Falcon X3 Pistol grip 802.11 a/b/g CCX v4 Bluetooth v2
Quicklinx: B7WHWS00 Mfr#: 945250037
The Datalogic Falcon X3 mobile computer takes the Falcon X3's industry leading pistol grip form to the next level of performance in ergonomics, computing and ease of use. The Falcon X3's Summit IEEE 802.11 a/b/g radio with CCX v4 certification from Cisco ensures seamless roaming in warehouse and logistics environments. Falcon X3 delivers rugged construction, laser and image data capture, along with real time communications in a product that is effortless to develop for, deploy and manage.
  • Real time data capture
    Capture with a high performance laser scanner with green spot, an auto ranging laser (XLR) scanner, or a 2D imager with green spot combined with a 3-megapixel color camera. Communicate over a Summit 802.11 a/b/g radio with CCX v4 certification for security and seamless roaming or through wired standards including USB, RS232, modem and Ethernet.
  • Ergonomic and rugged
    Ergonomic hand held and pistol grip form factors balance a 3.5-inch display and full keyboards. Functional rubberized plastic enclosures survive daily abuse and trauma from drops to concrete and exposure to water and dust. Users feel the full shift difference of oversized numeric and alphanumeric back lit keyboards, a crystal clear display and an arched pistol grip handle with ergonomic trigger.
Datalogic Falcon X3 - data collection terminal - Win CE 6.0 - 256 MB - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows CE 6.0
Display
3.5" colour TFT - 240 x 320
Intel XScale PXA310
Processor Clock Speed
624 MHz
Storage
256 MB integrated
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.0 EDR
Rear Camera
3 Megapixel
Barcode Reader
Yes (laser)
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, Code 32, Codabar, Code 128
8.8 cm x 16.8 cm x 22.5 cm
699 g
Operating System
Display
3.5" colour TFT (transflective)
Resolution
240 x 320
Colour Depth
64K colours (16-bit)
Intel XScale PXA310
624 MHz
Storage
256 MB integrated
RAM
256 MB
microSD, microSDHC
Communications
Rear Camera
Sensor Resolution
3 Megapixel
Light Source
LED light
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, stylus, navigation button, backlit keyboard
Keys Qty
52
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
Software
Preloaded Software
Microsoft Internet Explorer 6.0, MCL, Microsoft WordPad, Portable Applications Library (PAL), Wavelink Avalanche, Wavelink Studio, Wavelink Terminal Emulation, Wavelink Industrial Browser
Expansion and Connectivity
Expansion Slots
1 x microSDHC
1 x dock , 1 x serial RS-232 , 1 x headset , 2 x USB
Lithium Ion
5000 mAh
Water-resistant, dust-resistant, Green Spot technology, drop-resistant
Stylus, pistol grip handle
TUV, IP64, CCX V4
8.8 cm
16.8 cm
22.5 cm
699 g
-20 °C
50 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
