Your basket is empty
Datalogic Falcon X3 Pistol grip 802.11 a/b/g CCX v4 Bluetooth v2
Quicklinx: B7W6WS00 Mfr#: 945250008
  • Microsoft Windows Mobile 6.0
The Datalogic Falcon X3 mobile computer takes the Falcon X3's industry leading pistol grip form to the next level of performance in ergonomics, computing and ease of use. The Falcon X3's Summit IEEE 802.11 a/b/g radio with CCX v4 certification from Cisco ensures seamless roaming in warehouse and logistics environments. Falcon X3 delivers rugged construction, laser and image data capture, along with real time communications in a product that is effortless to develop for, deploy and manage.
Datalogic Falcon X3 - data collection terminal - Windows Mobile 6.0 - 256 MB - 3.5"
Data collection terminal - rugged
Operating System
Display
3.5" colour TFT - 240 x 320
Intel XScale PXA310
Processor Clock Speed
624 MHz
Storage
256 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.0 EDR
Camera
3 Megapixel (rear)
Barcode Reader
Yes (laser)
Barcodes
Code 93, Code 39, UCC/EAN-128, GS1 DataBar, Code 32, Codabar, Code 128
8.8 cm x 5.5 cm x 22.5 cm
0.63 kg
Operating System
Display
3.5" colour TFT (transflective)
Resolution
240 x 320
Colour Depth
64K colours (16-bit)
Intel XScale PXA310
624 MHz
Storage
256 MB
RAM
256 MB - SDRAM
microSD, microSDHC
Communications
Camera
Resolution (MP)
3 Megapixel (rear)
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, backlit keyboard
Keys Qty
29
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
Software
Preloaded Software
Microsoft Java Virtual Machine, Microsoft Internet Explorer 6.0, MCL, Microsoft WordPad, Portable Applications Library (PAL), Wavelink Avalanche, Wavelink Studio, Wavelink Terminal Emulation
Expansion and Connectivity
Expansion Slots
1 x microSD
2 x USB , 1 x serial RS-232 , 1 x headset
Lithium Ion
5000 mAh
Water-resistant, dust-resistant
TUV, IP64, CCX V4
8.8 cm
5.5 cm
22.5 cm
0.63 kg
-20 °C
50 °C
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
