The Datalogic Falcon X3 mobile computer takes the Falcon X3's industry leading pistol grip form to the next level of performance in ergonomics, computing and ease of use. The Falcon X3's Summit IEEE 802.11 a/b/g radio with CCX v4 certification from Cisco ensures seamless roaming in warehouse and logistics environments. Falcon X3 delivers rugged construction, laser and image data capture, along with real time communications in a product that is effortless to develop for, deploy and manage.
Real time data capture
Capture with a high performance laser scanner with green spot, an auto ranging laser (XLR) scanner, or a 2D imager with green spot combined with a 3-megapixel color camera. Communicate over a Summit 802.11 a/b/g radio with CCX v4 certification for security and seamless roaming or through wired standards including USB, RS232, modem and Ethernet. -
Ergonomic and rugged
Ergonomic hand held and pistol grip form factors balance a 3.5-inch display and full keyboards. Functional rubberized plastic enclosures survive daily abuse and trauma from drops to concrete and exposure to water and dust. Users feel the full shift difference of oversized numeric and alphanumeric back lit keyboards, a crystal clear display and an arched pistol grip handle with ergonomic trigger.
- Datalogic Falcon X3 - data collection terminal - Win CE 6.0 - 256 MB - 3.5"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows CE 6.0
- Display
- 3.5" colour TFT - 240 x 320
- Processor
- Intel XScale PXA310
- Processor Clock Speed
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11a/b/g, Bluetooth 2.0 EDR
- Rear Camera
- 3 Megapixel
- Barcode Reader
- Yes (laser)
- Barcodes
- Code 93, Code 39, UCC/EAN-128, GS1 DataBar, Code 32, Codabar, Code 128
- 8.8 cm x 5.5 cm x 22.5 cm
- 0.62 kg
- Product Type
- Operating System
Display
- 3.5" colour TFT (transflective)
- Resolution
- 240 x 320
- Colour Depth
- 64K colours (16-bit)
- Processor
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB - SDRAM
Communications
Rear Camera
- Sensor Resolution
- 3 Megapixel
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, navigation button, backlit keyboard
- Keys Qty
- 29
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
- Barcodes
- Minimum Bar Width
- 7.5 mil
Software
- Preloaded Software
- Microsoft Java Virtual Machine, Microsoft Internet Explorer 6.0, MCL, Microsoft WordPad, Portable Applications Library (PAL), Wavelink Studio, Wavelink Terminal Emulation, Datalogic Windows SDK, Wavelink Industrial Browser, Wavelink Avalanche Mobility Center, Wavelink Avalanche Site Edition, Wavelink Avalanche Remote Control, Wavelink Avalanche SecurePlus, Wavelink Certificate Manager, Wavelink Communicator, Wavelink SpeakEasy
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 2 x USB , 1 x serial RS-232 , 1 x headset
- Technology
- Lithium Ion
- Capacity
- 5000 mAh
- Green Spot technology
- TUV, IP64, CCX V4
- 8.8 cm
- 5.5 cm
- 22.5 cm
- 0.62 kg
- -20 °C
- 50 °C
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
