Elf offers the Windows Mobile 6.5 platform, with the Datalogic SDK and tools for integrating voice, pictures, and video to create or enhance existing mobility software solutions. Wavelink device management tools make Elf a simple device to both deploy and maintain.
Capitalizing on Datalogic Mobile's legendary ergonomics, the PDA packs unprecedented features into a compact form factor built for single handed use. Use of an accelerometer eliminates awkward presentation of on screen data and a unique guitar pick stylus provides for intuitive touch screen navigation.
The PDA provides four wireless technologies in the same form factor: Bluetooth EDR for fast data transfer, 802.11 a/b/g with Cisco certified security, UMTS HSDPA for real-time communication outside the enterprise Assisted GPS (A-GPS) with Skyhook's core engine hybrid positioning system for location based applications.
Feel and form
Capitalizing on Datalogic Mobile's legendary ergonomics, the PDA packs unprecedented features into a compact form factor built for single handed use. Use of an accelerometer eliminates awkward presentation of on screen data and a unique guitar pick stylus provides for intuitive touch screen navigation. -
Compute
A micro SD card slot supporting SDHC storage cards provides for virtually unlimited storage space for photos taken with the onboard 3-megapixel camera. -
Capture
Both a 1D laser scanner and 2D bar code imager enable a wide array of bar codes seen across diverse enterprises. Both have Datalogic's patented Green Spot good read technology to improve user efficiency and accuracy HF RFID readers available in combination with barcode readers complete the package. -
Communicate
The PDA provides four wireless technologies in the same form factor: Bluetooth EDR for fast data transfer, 802.11 a/b/g with Cisco certified security, UMTS HSDPA for real-time communication outside the enterprise Assisted GPS (A-GPS) with Skyhook's core engine hybrid positioning system for location based applications. -
Develop, deploy, direct
Elf offers the Datalogic SDK and tools for integrating voice, pictures, and video to create or enhance existing mobility software solutions. Wavelink device management tools make Elf a simple device to both deploy and maintain.
- Datalogic Elf - data collection terminal - Win CE 6.0 - 256 MB - 3.5"
- Product Type
- Data collection terminal - rugged
- Operating System
- Microsoft Windows CE 6.0
- Display
- 3.5" colour TFT - 640 x 480
- Processor
- Intel XScale PXA310
- Processor Clock Speed
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB
- Supported Flash Memory Cards
- microSD, microSDHC
- Wireless Connectivity
- 802.11a/b/g, Bluetooth 2.0 EDR
- Barcode Reader
- Yes (laser)
- Barcodes
- Code 93, Code 39, GS1 DataBar, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Plessey
- 8.1 cm x 4.2 cm x 15.7 cm
- Product Type
- Operating System
Display
- 3.5" colour TFT (reflective)
- Resolution
- 640 x 480
- Processor
- 624 MHz
- Storage
- 256 MB
- RAM
- 256 MB
Communications
Multimedia
- Audio
- Microphone, speaker
Input Device
- Touch-screen, keypad
- Keys Qty
- 27
Barcodes
- Barcode Reader
- Scan Element Type
- Laser
- Barcodes
- Max Working Distance
- 64 cm
- Minimum Bar Width
- 4 mil
Expansion and Connectivity
- Expansion Slots
- 1 x microSD
- 1 x USB 2.0 , 1 x USB , 1 x serial RS-232
- Installed Qty (Max Supported)
- 1
- Technology
- Lithium Ion
- Water-resistant, dust-resistant, Green Spot technology
- Included Accessories
- Power adapter
- TUV, Bluetooth Class 2, ISO 9000, IP64, ISO 15693, CCX V4, EN 60825-1
- 8.1 cm
- 4.2 cm
- 15.7 cm
- -10 °C
- 50 °C
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
