Datalogic Elf Data Collection Terminal
Quicklinx: 91RFWS00 Mfr#: 944301015
Elf offers the Windows Mobile 6.5 platform, with the Datalogic SDK and tools for integrating voice, pictures, and video to create or enhance existing mobility software solutions. Wavelink device management tools make Elf a simple device to both deploy and maintain.
Capitalizing on Datalogic Mobile's legendary ergonomics, the PDA packs unprecedented features into a compact form factor built for single handed use. Use of an accelerometer eliminates awkward presentation of on screen data and a unique guitar pick stylus provides for intuitive touch screen navigation.
The PDA provides four wireless technologies in the same form factor: Bluetooth EDR for fast data transfer, 802.11 a/b/g with Cisco certified security, UMTS HSDPA for real-time communication outside the enterprise Assisted GPS (A-GPS) with Skyhook's core engine hybrid positioning system for location based applications.
  • Feel and form
  • Compute
    A micro SD card slot supporting SDHC storage cards provides for virtually unlimited storage space for photos taken with the onboard 3-megapixel camera.
  • Capture
    Both a 1D laser scanner and 2D bar code imager enable a wide array of bar codes seen across diverse enterprises. Both have Datalogic's patented Green Spot good read technology to improve user efficiency and accuracy HF RFID readers available in combination with barcode readers complete the package.
  • Communicate
  • Develop, deploy, direct
    Elf offers the Datalogic SDK and tools for integrating voice, pictures, and video to create or enhance existing mobility software solutions. Wavelink device management tools make Elf a simple device to both deploy and maintain.
Datalogic Elf - data collection terminal - Win CE 6.0 - 256 MB - 3.5"
Data collection terminal - rugged
Operating System
Microsoft Windows CE 6.0
Display
3.5" colour TFT - 640 x 480
Intel XScale PXA310
Processor Clock Speed
624 MHz
Storage
256 MB
RAM
256 MB
Supported Flash Memory Cards
microSD, microSDHC
Wireless Connectivity
802.11a/b/g, Bluetooth 2.0 EDR
Barcode Reader
Yes (laser)
Barcodes
Code 93, Code 39, GS1 DataBar, Codabar, Code 128, Code 11, Code 2 of 5, UPC, Plessey
8.1 cm x 4.2 cm x 15.7 cm
Operating System
Display
3.5" colour TFT (reflective)
Resolution
640 x 480
Intel XScale PXA310
624 MHz
Storage
256 MB
RAM
256 MB
microSD, microSDHC
Communications
Multimedia
Audio
Microphone, speaker
Input Device
Touch-screen, keypad
Keys Qty
27
Barcodes
Barcode Reader
Scan Element Type
Laser
Barcodes
Max Working Distance
64 cm
Minimum Bar Width
4 mil
Expansion and Connectivity
Expansion Slots
1 x microSD
1 x USB 2.0 , 1 x USB , 1 x serial RS-232
Installed Qty (Max Supported)
1
Lithium Ion
Water-resistant, dust-resistant, Green Spot technology
Power adapter
TUV, Bluetooth Class 2, ISO 9000, IP64, ISO 15693, CCX V4, EN 60825-1
8.1 cm
4.2 cm
15.7 cm
-10 °C
50 °C
Min Storage Temperature
-20 °C
Max Storage Temperature
70 °C
