The PowerScan 7100 product series is Datalogic Scanning's value line of rugged industrial handheld data collection product. The PowerScan D7100 linear imaging corded reader combines rugged durability and extremely snappy reading performance all at an affordable price.
Datalogic Scanning's innovative and unique optical design of the PowerScan 7100 series of readers combines scanner features that are normally available on different scanner models into a single device: up to 3 mils maximum code resolution; contact to about 3.0 m / 9.8 ft reading distance; and wide angle code reading. The result is a versatile, easy to use and intuitive scanner that simplifies any code reading activity.
Together high-speed digital hardware and Datalogic Scanning's advanced decoding algorithms produce read rates up to 390 scans per second, making the PowerScan 7100 readers the fastest industrial scanners available. This is why the 7100's are especially suitable for "high-speed" applications where thousands of codes have to be read in a very short period of time
As with all PowerScan products, the 7100 readers' mechanics have been developed and tested to withstand extreme environmental conditions while maintaining consistent reading performance. A loud beeper and Datalogic's exclusive patented ‘Green Spot' directly on the code, provide intuitive good read feedback in noisy environments.
Light weight and instinctive usage combined with outstanding speed-to-read makes the 7100 product series the ideal solution for intensive code reading applications.
- Datalogic PowerScan PD7130 - barcode scanner
- Barcode scanner - handheld - USB - decoded
- Black, yellow
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Visible laser diode
- Scan Speed
- 390 scan / sec
- Connectivity Technology
- Wired
- 7.6 cm x 11.4 cm x 20.3 cm
- 280 g
- 3-year warranty
- Black, yellow
Barcode
- Interface Type
- USB
- Minimum Bar Width
- 3 mil
- Scan Element Type
- Light Source Wave Length
- 630-680 nm
- Scan Mode
- Single-pass
- Scan Speed
- 390 scan / sec
- Skew (Degrees)
- 65
- Pitch (Degrees)
- 65
- Print Contrast Signal (PCS)
- 15%
- Decode Capability
- Code 93, Industrial 2 of 5, Code 39, ISBT 128, IATA, GS1 DataBar, Code 32, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Code 128, Code 11, Interleaved 2 of 5, MSI-Plessey, Codablock F, Label Codes 4/5
- TTL Decoding
- Decoded
- Wired
- OK Notification
- Beeper, LED indicator
- 1 x USB
- IEC 825-1/EN 60825-1 class 1, RoHS
Software
- Software Included
- Datalogic Aladdin
- 7.6 cm
- 11.4 cm
- 20.3 cm
- 280 g
- Limited warranty - 3 years
- -30 °C
- 50 °C
- 5 - 95%
- Drop Specification
- 2 m to concrete
