Your basket is empty
DataCard SP 25 Plus With Input Hopper
Quicklinx: C0DSWS00 Mfr#: 573608-010
The Datacard SP25 Plus printer offers a unique combination of full-color and rewritable card printing capabilities.
This one-sided printer is designed for low-volume, manual-feed applications and is an ideal solution for issuing retail/loyalty, membership and ID cards.
Datacard SP25 Plus - plastic card printer - colour - dye sublimation/rewritable
Printer Type
Plastic card printer - dye sublimation/rewritable - colour
3.2 kg
Max Media Size
CR-80 Card (85.6 x 54 mm)
Max Media Size (Custom)
54 mm x 86 mm
Print Speed
Up to 120 cards/hour - colour - CR-80 Card (85.6 x 54 mm) , Up to 500 cards/hour - monochrome - CR-80 Card (85.6 x 54 mm)
Max Resolution (B&W)
300 dpi
Max Resolution (Colour)
300 dpi
Image Enhancement Technology
Advanced Imaging Technology
USB
Media Type
Card, laminated PVC card, ThermoRewrite card
Printer Features
Borderless printing, ribbon saver
AC 120/230 V
Linux, Microsoft Windows 2000 / XP, Microsoft Windows Server 2003, Microsoft Windows Vista, Microsoft Windows Server 2008
2 years warranty
19.5 cm x 37.85 cm x 22.5 cm
Printer Type
Printer
Print Speed
Up to 120 cards/hour - colour - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 500 cards/hour - monochrome - 300 dpi - CR-80 Card (85.6 x 54 mm)
Wired
USB
300 dpi
300 dpi
Printer Features
Media Handling
Media Type
Max Media Size
54 mm x 86 mm
Card / Label Sizes
Media Thickness Range
0.2286 mm - 1.397 mm
1 x USB
Consumables Included
2 x ribbon (yellow/cyan/magenta) - up to 250 images
UL, C-Tick, cUL, CCC, FCC, RoHS
Power adapter - external
AC 120/230 V
Frequency Required
50/60 Hz
Software Included
Drivers & Utilities, Datacard ID Works Basic Edition
Limited warranty - 2 years , Limited warranty - printhead - 2 years
15 °C
35 °C
20 - 80% (non-condensing)
19.5 cm
37.85 cm
22.5 cm
3.2 kg
