DataCard SD360 Duplex Printer
Quicklinx: BWM9WS00 Mfr#: 506339-001
Bring even more value to your desktop with the Datacard SD360 card printer. Increase productivity and save work time by issuing secure, two-sided ID cards and badges with this best-in-class card printer. Ideal applications include small- to medium-sized businesses, schools, clubs and hospitals.
  • Issue secure credentials more easily with automatic two-sided printing
    Create customized cards and badges with automatic two-sided printing. The SD360 card printer produces outstanding, dual-sided ID cards that are both visually impressive and easy to produce.
  • Superior speed for higher productivity
    Reduce the hassle of jamming with Datacard's exclusive TruePick card handling. Work time and efficiency can both be increased with the SD360 card printer, which produces clean credentials at industry-leading speeds.
  • Technology prints brighter, high-quality images
    Impress cardholders with the crisp, clean images and vibrant colors printed by the SD360 card printer. Datacard's exclusive TrueMatch printing technology closely matches the colors on your card to the colors on your screen. Produce two-sided cards in full-color, up to 256 shades per color panel.
  • Intuitive operation simplifies card printing
    There's very little learning curve with the SD360 card printer. Printer operations are easy to understand with the help of the intuitive soft-touch LCD panel. Load cards, replace supplies and access all the industry-leading features from one location on the compact SD360 printer, which includes a built-in 100-card input hopper and 25-card output hopper.
  • All the right connections for easy setup
    Standard, built-in Ethernet and US ports, and the browser-based printer manager, help you integrate the SD360 printer into just about any application or typical IT environment.
  • Engineered for Earth-friendly performance
    Save energy and strengthen corporate environmental commitments with the Earth-friendly and ENERGY STAR qualified SD360 card printer, which is built to consume less electricity than its predecessors. Biodegradable supply cores, recyclable materials and power-down button set new benchmarks for environmentally responsible card printing.
Datacard SD360 - plastic card printer - colour - dye sublimation/thermal resin
Printer Type
Plastic card printer - dye sublimation/thermal resin - colour
Desktop
5.4 kg
Max Media Size
CR-80 Card (85.6 x 54 mm)
Print Speed
Up to 200 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
Max Resolution (Colour)
300 dpi
Automatic Duplexing
USB, LAN
RAM Installed (Max)
128 MB
Media Type
Plastic cards
Total Media Capacity
100 cards
Media Handling
100-cards input hopper
Print server - Ethernet, Fast Ethernet
30 months warranty
17.5 cm x 53.9 cm x 22.4 cm
Printer Type
Desktop
Printer
Print Speed
Up to 200 cards/hour - colour single-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
Built-in Devices
Status LCD
Wired
USB, LAN
300 dpi
Automatic Duplexing
Media Handling
RAM
RAM Installed (Max)
128 MB
Media Handling
Media Type
Plastic cards
Max Media Size
Card / Label Sizes
Media Thickness Range
0.254 mm - 0.939 mm
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Output Trays Capacity
25 cards
Print server
1 x USB , 1 x LAN - RJ-45
Cleaning pen, cleaning kit
1 x USB cable
VCCI, C-Tick, WHQL, CCC, IC, FCC, RoHS, WEEE, cULus
Frequency Required
50/60 Hz
Software Included
Driver
Environmental Standards
ENERGY STAR
Limited warranty - 30 months , Limited warranty - printhead - 30 months
15 °C
35 °C
20 - 80% (non-condensing)
17.5 cm
53.9 cm
22.4 cm
5.4 kg
