Bring even more value to your desktop with the Datacard SD360 card printer. Increase productivity and save work time by issuing secure, two-sided ID cards and badges with this best-in-class card printer. Ideal applications include small- to medium-sized businesses, schools, clubs and hospitals.
Issue secure credentials more easily with automatic two-sided printing
Create customized cards and badges with automatic two-sided printing. The SD360 card printer produces outstanding, dual-sided ID cards that are both visually impressive and easy to produce. -
Superior speed for higher productivity
Reduce the hassle of jamming with Datacard's exclusive TruePick card handling. Work time and efficiency can both be increased with the SD360 card printer, which produces clean credentials at industry-leading speeds. -
Technology prints brighter, high-quality images
Impress cardholders with the crisp, clean images and vibrant colors printed by the SD360 card printer. Datacard's exclusive TrueMatch printing technology closely matches the colors on your card to the colors on your screen. Produce two-sided cards in full-color, up to 256 shades per color panel. -
Intuitive operation simplifies card printing
There's very little learning curve with the SD360 card printer. Printer operations are easy to understand with the help of the intuitive soft-touch LCD panel. Load cards, replace supplies and access all the industry-leading features from one location on the compact SD360 printer, which includes a built-in 100-card input hopper and 25-card output hopper. -
All the right connections for easy setup
Standard, built-in Ethernet and US ports, and the browser-based printer manager, help you integrate the SD360 printer into just about any application or typical IT environment. -
Engineered for Earth-friendly performance
Save energy and strengthen corporate environmental commitments with the Earth-friendly and ENERGY STAR qualified SD360 card printer, which is built to consume less electricity than its predecessors. Biodegradable supply cores, recyclable materials and power-down button set new benchmarks for environmentally responsible card printing.
- Datacard SD360 - plastic card printer - colour - dye sublimation/thermal resin
- Printer Type
- Plastic card printer - dye sublimation/thermal resin - colour
- Form Factor
- Desktop
- 5.4 kg
- Max Media Size
- CR-80 Card (85.6 x 54 mm)
- Print Speed
- Up to 200 cards/hour - colour single-sided - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
- Max Resolution (Colour)
- 300 dpi
- Automatic Duplexing
- Interface
- USB, LAN
- RAM Installed (Max)
- 128 MB
- Media Type
- Plastic cards
- Total Media Capacity
- 100 cards
- Media Handling
- 100-cards input hopper
- Networking
- Print server - Ethernet, Fast Ethernet
- 30 months warranty
- 17.5 cm x 53.9 cm x 22.4 cm
- Printer Type
- Form Factor
- Desktop
Printer
- Print Speed
- Up to 200 cards/hour - colour single-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 155 cards/hour - colour dual-sided - 300 dpi - CR-80 Card (85.6 x 54 mm) , Up to 830 cards/hour - B/W - CR-80 Card (85.6 x 54 mm)
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- USB, LAN
- 300 dpi
- Media Handling
RAM
- 128 MB
Media Handling
- Media Type
- Plastic cards
- Max Media Size
- Card / Label Sizes
- Media Thickness Range
- 0.254 mm - 0.939 mm
- 100 cards
- Media Feeders
- 1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
- Output Trays Capacity
- 25 cards
- Networking
- Print server
- Data Link Protocol
- Connections
- 1 x USB , 1 x LAN - RJ-45
- Included Accessories
- Cleaning pen, cleaning kit
- Cables Included
- 1 x USB cable
- VCCI, C-Tick, WHQL, CCC, IC, FCC, RoHS, WEEE, cULus
- Frequency Required
- 50/60 Hz
- Software Included
- Driver
Environmental Standards
- ENERGY STAR
- Limited warranty - 30 months , Limited warranty - printhead - 30 months
- 15 °C
- 35 °C
- 20 - 80% (non-condensing)
- 17.5 cm
- 53.9 cm
- 22.4 cm
- 5.4 kg
