DataCard SD160 Simplex 100-Card Printer
Quicklinx: BRVRWS00 Mfr#: 510685-001
Type: Printer
Functionality: Printer
Wireless Capability: Wired
Technology: Dye sublimation
Max Paper Size: CR-80 Card (85.6 x 54 mm)
  • Windows 8.1 (32/64 bits)
£561.41 ex VAT
£673.69 inc VAT
The affordable and efficient Datacard SD160 card printer offers the right combination of technologies to meet a wide range of application requirements. Direct-to-card (DTC) printing technologies provide the versatility to reliably produce attractive cards with high quality, full-color or monochrome photos, graphics and text.
  • Ultimate value
    With entry-level pricing, the SD160 printer is a smart choice for efficiently producing a variety of high quality cards to get your ID program started. The SD160 has unique low yield print ribbons that allows you to meet your card printing needs as they arise.
  • Full versatility and flexibility
    The SD160 card printer offers full-color or monochrome printing with single-pass efficiency - plus inline magnetic stripe encoding. Print cards for many types of applications, including corporate IDs, healthcare IDs, student, visitor or staff badges, and retail, hospitality or loyalty cards.
  • Less user intervention
    The SD160 printer is simple and intuitive to operate and maintain. Minimal training and easy installation get you set up and printing quickly.
Datacard SD160 - plastic card printer - colour - dye sublimation/thermal resin
Printer Type
Plastic card printer - dye sublimation/thermal resin - colour
3.7 kg
Max Media Size
Print Speed
Up to 150 cards/hour - colour , Up to 500 cards/hour - B/W
Max Resolution (Colour)
300 dpi
USB 2.0
Media Type
Plastic cards
Total Media Capacity
100 cards
Media Handling
100-cards input hopper
Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012 x64 Edition, Windows 8.1 (32/64 bits)
17.5 cm x 39.1 cm x 22.4 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB 2.0
300 dpi
Media Handling
Media Handling
Media Type
Plastic cards
Max Media Size
Card / Label Sizes
100 cards
Media Feeders
1 x automatic - 100 cards - CR-80 Card (85.6 x 54 mm)
Output Trays Capacity
25 cards
1 x USB 2.0
Cleaning kit
1 x USB cable
Power adapter - external
Software Included
Drivers & Utilities
Limited warranty - 2 years , Limited warranty - printhead - 2 years
17.5 cm
39.1 cm
22.4 cm
3.7 kg
Type: Printer
Brand: DataCard
Price Range Ex VAT: £500 - £750
