The xStack DGS-3420 series of next generation Layer 2+ Gigabit switches delivers performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises. With high Gigabit port densities, Gigabit SFP, 10-Gigabit SFP+ support, and advanced software solutions, these switches can act as either departmental access layer devices or aggregation switches to form a multilevel network structured with backbone and centralized high-speed servers.
Unparalleled flexibility
Easily deployed and simple to manage, the DGS-3420 can be stacked with any switch that supports D-Link's single IP management to form a multi-level network structured with backbone and centralized high-speed servers. -
Redundant ring stacking
Alternatively, depending on whether linear or fault tolerant ring stacking is implemented, users can use one or two 10-Gigabit SFP+ ports to create a physical stack. -
Security, performance and availability
The DGS-3420 series provides a complete set of security features including L2/L3/L4 multi-layer Access Control Lists and 802.1X user authentication via TACACS+ and RADIUS servers. The DGS-3420 series offers extensive VLAN support including GVRP and 802.1Q VLAN to enhance security and performance. -
IPv6 technology
The DGS-3420 series also features comprehensive IPv6 support, including IPv6 Tunnel, ICMPv6, DHCPv6, RIPng, and more. With 10-Gigabit connectivity and IPv6 support, the series enables you to future-proof your network for cost efficiency and longevity while meeting the requirements that future IPv6 capable network devices require. -
D-Link Green technology
D-Link is striving to take the lead in developing innovative and power-saving technology that does not sacrifice operational performance or functionality. The DGS-3420 series implements D-Link Green technology, which includes power saving through link status, smart fan design, increased heat dissipation, and cable length detection.
- D-Link xStack DGS-3420-52P - switch - 48 ports - Managed - rack-mountable
- Switch - 48 ports - Managed - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 48 x 10/100/1000 (PoE) + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps
- Capacity
- IPv4 routing table entries: 1024 , IPv6 routing table entries: 512 , IPv4 forwarding table entries: 2048 , IPv6 forwarding table entries: 1024
- MAC Address Table Size
- 16K entries
- Jumbo Frame Support
- 13000 bytes
- Routing Protocol
- RIP-1, RIP-2, static IP routing, RIPng
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
- Flow control, full duplex capability, BOOTP support, ARP support, VLAN support, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, sFlow, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Safeguard Engine, bandwidth control, Link Aggregation Control Protocol (LACP), 2MB packet buffer
- IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ak, IEEE 802.3at, IEEE 802.1AX
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 31 cm x 4.4 cm
- 6.4 kg
- Enclosure Type
- Desktop, rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- Capacity
- 16K entries
- 13000 bytes
- Max Units In A Stack
- 12
- Routing Protocol
- Encryption Algorithm
- SSL, SSL 3.0, SSL 2.0
- Authentication Method
- Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2)
- RAM
- 256 MB
- Status Indicators
- Power, RPS (Redundant Power Supply), PoE, link/activity, console
- 48 x 1000Base-T RJ-45 PoE , 1 x console RJ-45 management , 4 x SFP+
- Power Device
- Internal power supply
- Voltage Required
- 505.4 Watt
- Redundant Power System (RPS) connector
- FCC Class A certified, UL, C-Tick, cUL, VCCI Class A ITE, CB, IC, RoHS, LVD
- 44.1 cm
- 31 cm
- 4.4 cm
- 6.4 kg
- 0 °C
- 50 °C
- 10 - 90%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90%
