Product
D-Link xStack 48port 10/100/1000/10G L2+ Stack Switch+4x10GE SFP+
Quicklinx: 7XCPWS00 Mfr#: DGS-3420-52T
Type: Gigabit Ethernet
Ports: 48
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
Hurry, only 1 left in stock!
£1,605.98 ex VAT
£1,927.17 inc VAT
The xStack DGS-3420 series of next generation Layer 2+ Gigabit switches delivers performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises. With high Gigabit port densities, Gigabit SFP, 10-Gigabit SFP+ support, and advanced software solutions, these switches can act as either departmental access layer devices or aggregation switches to form a multilevel network structured with backbone and centralized high-speed servers.
  • Unparalleled flexibility
    Easily deployed and simple to manage, the DGS-3420 can be stacked with any switch that supports D-Link's single IP management to form a multi-level network structured with backbone and centralized high-speed servers.
  • Redundant ring stacking
    Alternatively, depending on whether linear or fault tolerant ring stacking is implemented, users can use one or two 10-Gigabit SFP+ ports to create a physical stack.
  • Security, performance and availability
    The DGS-3420 series provides a complete set of security features including L2/L3/L4 multi-layer Access Control Lists and 802.1X user authentication via TACACS+ and RADIUS servers. The DGS-3420 series offers extensive VLAN support including GVRP and 802.1Q VLAN to enhance security and performance.
  • IPv6 technology
    The DGS-3420 series also features comprehensive IPv6 support, including IPv6 Tunnel, ICMPv6, DHCPv6, RIPng, and more. With 10-Gigabit connectivity and IPv6 support, the series enables you to future-proof your network for cost efficiency and longevity while meeting the requirements that future IPv6 capable network devices require.
  • D-Link Green technology
    D-Link is striving to take the lead in developing innovative and power-saving technology that does not sacrifice operational performance or functionality. The DGS-3420 series implements D-Link Green technology, which includes power saving through link status, smart fan design, increased heat dissipation, and cable length detection.
D-Link xStack DGS-3420-52T - switch - 48 ports - Managed - rack-mountable
Switch - 48 ports - Managed - stackable
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
48 x 10/100/1000 + 4 x 10 Gigabit SFP+
Performance
Switching capacity: 176 Gbps , Forwarding performance: 130.95 Mpps
IPv4 routing table entries: 1024 , IPv6 routing table entries: 512 , IPv4 forwarding table entries: 2048 , IPv6 forwarding table entries: 1024
MAC Address Table Size
16K entries
Jumbo Frame Support
13000 bytes
Routing Protocol
RIP-1, RIP-2, static IP routing, RIPng
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Flow control, full duplex capability, BOOTP support, ARP support, VLAN support, IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, store and forward, Broadcast Storm Control, IPv6 support, Multicast Storm Control, Unicast Storm Control, sFlow, Spanning Tree Protocol (STP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, MLD snooping, Safeguard Engine, bandwidth control, Link Aggregation Control Protocol (LACP), 2MB packet buffer
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.3ah, IEEE 802.1v, IEEE 802.1ak, IEEE 802.1AX
44.1 cm x 31 cm x 4.4 cm
5.1 kg
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
Performance
16K entries
Jumbo Frame Support
13000 bytes
Max Units In A Stack
12
Routing Protocol
Encryption Algorithm
SSL, SSL 3.0, SSL 2.0
Authentication Method
Secure Shell (SSH), RADIUS, Secure Shell v.2 (SSH2)
RAM
256 MB
Status Indicators
Power, RPS (Redundant Power Supply), link/activity, console
48 x 1000Base-T RJ-45 , 1 x console RJ-45 management , 4 x SFP+
Internal power supply
81 Watt
Redundant Power System (RPS) connector
MTBF
255,608 hours
FCC Class A certified, UL, C-Tick, cUL, VCCI Class A ITE, CB, IC, RoHS, LVD
44.1 cm
31 cm
4.4 cm
5.1 kg
50 °C
10 - 90%
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90%
Ports: 48
Managed: Yes
POE: No
Brand: D-Link
Price Range Ex VAT: 1500+
