The DGS-3620 Series xStack L3 Managed Stackable Gigabit Switches deliver great performance, flexibility, security, multi-layer QoS, and accessibility, along with redundant power solutions for SMBs and enterprises.
- D-Link xStack DGS-3620-28PC - switch - 24 ports - Managed
- Switch - 24 ports - L3 - Managed - stackable
- Enclosure Type
- 1U
- Subtype
- Gigabit Ethernet
- Ports
- 20 x 10/100/1000 + 4 x combo Gigabit SFP + 4 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE
- Performance
- Switching capacity: 128 Gbps , Forwarding performance: 95.24 Mpps
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 13000 bytes
- Routing Protocol
- OSPF, RIP-1, RIP-2, IGMPv2, IGMP, VRRP, OSPFv2, PIM-SM, PIM-DM, IGMPv3, GRE, PIM-SSM, policy-based routing (PBR), Bidirectional Forwarding Detection (BFD)
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, Telnet, SNMP 3, SNMP 2c, TFTP, CLI
- Flow control, full duplex capability, power over Ethernet (PoE), BOOTP support, trunking, VLAN support, IGMP snooping, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, SNTP support, sFlow, Spanning Tree Protocol (STP) support, Rapid Spanning Tree Protocol (RSTP) support, Multiple Spanning Tree Protocol (MSTP) support, Trivial File Transfer Protocol (TFTP) support, Access Control List (ACL) support, Quality of Service (QoS), DHCP server, PoE+, Equal-Cost Multipath (ECMP), Uni-Directional Link Detection (UDLD), LLDP support, Link Aggregation Control Protocol (LACP), Remote Switch Port Analyzer (RSPAN)
- IEEE 802.3, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.3ah, IEEE 802.1v, IEEE 802.3at
- Power
- AC 120/230 V (50/60 Hz)
- 44.1 cm x 31 cm x 4.4 cm
- 4.1 kg
- Limited lifetime warranty
- Enclosure Type
- Desktop 1U
- Subtype
- Gigabit Ethernet
- Ports
- PoE
- Performance
- 32K entries
- 13000 bytes
- Max Units In A Stack
- 12
- Routing Protocol
- Encryption Algorithm
- SSL, SSL 2.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- RAM
- 256 MB
- 4 x SFP (mini-GBIC) , 1 x console RJ-45 management , 24 x 1000Base-T RJ-45 , 4 x SFP+
- Expansion Slots
- 1 SD Memory Card
- Power Device
- Internal power supply
- Voltage Required
- Redundant Power System (RPS) connector
- FCC Class A certified, UL, VCCI, C-Tick, cUL, RoHS, GOST-R
- Software Included
- Standard Image (SI) Software
- 44.1 cm
- 31 cm
- 4.4 cm
- 4.1 kg
- Limited warranty - lifetime
- 0 °C
- 50 °C
- 10 - 90%
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90%
