D-Link Wireless N Day & Night Pan/Tilt Cloud Camera
Quicklinx: 9TT0WS00 Mfr#: DCS-5020L/B
View more, do more, and protect more with the clarity and mobile control of D-Link's pan and tilt day/night network camera (DCS-5020L). Experience confident clarity and total control with the ultra-smooth pan/tilt and digital zoom functionality. Integrated motion-sensing and night-vision technology provides around-the-clock surveillance. With simple installation, you'll have an effective affordable home or business surveillance solution up and running in no time.
The DCS-5020L provides the performance of a professional home or business surveillance solution at a fraction of the cost. Ultra-smooth pan/tilt and zoom functionality lets you monitor with precision and confidence from your mobile device. Why wait for a costly technician to install your system? With the DCS-5020L, installation is fast, easy, and flexible. The integrated night vision, sound and motion-sensing technology gives you peace of mind and around-the-clock surveillance. Whether you're looking for a superior home surveillance solution or a versatile way to monitor your small business, D-Link's DCS-5020L lets you see more of what matters.
  • Keep an eye on what matters most
  • Home and small business surveillance
  • Industry leading motion and sound alerts
    Built with motion and audio sensing technology, the DCS-5020L is capable of triggering instant e-mail alerts and auto-recording based on changes in your camera's environment. The intuitive mydlink interface allows you to quickly customize your settings, so you can have full control of how and when you want to be alerted. Easily setup volume thresholds and watch-zones to be instantly notified when your camera detects excessive noise levels or strange activity.
D-Link DCS 5020L Wireless N Day & Night Pan/Tilt Cloud Camera - network surveillance camera
Network surveillance camera - pan / tilt
Audio
Yes: built-in microphone
10.13 cm x 10.24 cm x 13.36 cm
292.4 g
Wired, wireless
Camera
Colour - Day&Night
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/5"
Minimum Illumination
0 lux - IR - F2.0
Focal Length
2.2 mm
Lens Iris
F/2.0
Panning Range (degree)
-170 to +170
Tilting Range (degree)
-25 to +95
Ethernet 10Base-T/100Base-TX, IEEE 802.11n
Voltage
DC 12 V
Date/time stamp, saturation control, brightness control, contrast control, infrared cut filter, Wi-Fi Protected Setup (WPS)
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 85% (non-condensing) relative humidity
Audio Support
Wired, wireless
10.13 cm
10.24 cm
13.36 cm
292.4 g
Camera
Colour - Day&Night - pan / tilt
Digital Video Format
MJPEG, H.264
Max Digital Video Resolution
640 x 480
Digital Zoom
4
0 lux - IR - F2.0
Supported Image Formats
JPEG
Image Sensor
CMOS 1/5"
Lens Construction
Focal Length
2.2 mm
Lens Iris
F/2.0
Horizontal Field of View (degree)
66.22
Vertical Field of View (degree)
49.08
Panning
Range (degree)
-170 to +170
Tilting
Range (degree)
-25 to +95
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
C-Tick, IC, FCC
Power Requirements
DC 12 V
Power adapter - external 8.64 Watt
Microsoft Windows Vista / XP / 7 / 8
Relative Humidity (operating)
9TT0 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
