Wirelessly connect your computer or laptop to a high speed Wi-Fi network with the D-Link Wireless N150 USB Adapter (DWA-125) and transfer files and browse the Internet from greater distances across your home than previous Wireless G technology.
- D-Link DWA-125 - network adapter - USB
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB
- 3.8 cm x 8.9 cm x 1.3 cm
- 45 g
- Data Link Protocol
- 802.11b/g/n
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
- System Requirements
- Microsoft Windows XP SP2, Microsoft Windows Vista
- Microsoft Certification
- Compatible with Windows 7
- Designed For
- D-Link DIR-600, DSL-2680
- Network adapter
- Form Factor
- External
- USB
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Status Indicators
- Link/activity
- WPS
- Connections
- 1 x USB - 4 pin USB Type A
- Cables Included
- 1 x USB extension cable (external)
- Encryption Algorithm
- WPA, WPA2
- FCC Class B certified, IC
- OS Required
- 3.8 cm
- 8.9 cm
- 1.3 cm
- 45 g
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.09 |
