Your basket is empty
D-Link Wireless N 150 USB Adapter
Quicklinx: 7CHNWS00 Mfr#: DWA-125
  • IEEE 802.11n
Wirelessly connect your computer or laptop to a high speed Wi-Fi network with the D-Link Wireless N150 USB Adapter (DWA-125) and transfer files and browse the Internet from greater distances across your home than previous Wireless G technology.
D-Link DWA-125 - network adapter
Network adapter
External
Interface (Bus) Type
USB
3.8 cm x 8.9 cm x 1.3 cm
45 g
802.11b, 802.11g, 802.11n
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n
Microsoft Windows XP SP2, Microsoft Windows Vista
Microsoft Certification
Compatible with Windows 7
D-Link DIR-600, DSL-2680
Network adapter
External
USB
Wireless
Status Indicators
Link/activity
Wi-Fi Protected Setup (WPS)
1 x USB - 4 pin USB Type A
1 x USB extension cable (external)
Encryption Algorithm
WPA, WPA2
FCC Class B certified, IC
3.8 cm
8.9 cm
1.3 cm
45 g
10 - 90%
7CHN C2G 2m USB 2.0 A/B Cable - Black In Stock £3.02
7CHN C2G 5m USB 2.0 A/B Cable - Black In Stock £4.42
7CHN C2G 2-Port USB 2.0 Manual Switch In Stock £16.36
7CHN C2G 5m USB 2.0 A Male to A Female Active Extension Cable In Stock £11.41
7CHN C2G 4-Port USB 2.0 Aluminum Hub In Stock £25.45
7CHN C2G 12m USB 2.0 A/A Active Extension Cable In Stock £14.97
