Your basket is empty
D-Link Wireless N 150 Micro USB Adapter
Quicklinx: 8KLHWS00 Mfr#: DWA-121
Wired / Wireless: Wireless
Protocol: IEEE 802.11n
Form Factor: External
Compatibility: PC
Type: Network adapter
  • IEEE 802.11n
More than 50 in stock
£10.63 ex VAT
£12.75 inc VAT
Standard delivery Delivered within 3-5 working days
Connect your notebook or desktop computer to a high-speed Wi-Fi network using the D-Link Wireless N 150 Pico USB Adapter (DWA-121). The Wireless N 150 Pico USB Adapter lets you connect to any Wireless N150 network, so it's an excellent solution for everyday activities such as transferring files or browsing the Internet.
D-Link Wireless N DWA-121 - network adapter
Network adapter
External
Interface (Bus) Type
USB
1.9 cm x 1.4 cm x 0.6 cm
802.11g, 802.11n
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
2 years warranty
D-Link DIR-600
Network adapter
External
USB
Wireless
802.11g, 802.11n
Frequency Band
2.4 GHz
Status Indicators
Link/activity
Wi-Fi Protected Setup (WPS)
Aerial
Antenna
Internal
Antenna Qty
1
1 x USB - 4 pin USB Type A
Encryption Algorithm
WPA, WPA2, WPA2-PSK
FCC Class B certified, IC
1.9 cm
1.4 cm
0.6 cm
10 - 90% (non-condensing)
D-Link DIR-600
Compatibility: PC
Brand: D-Link
Price Range Ex VAT: 0 - 50
