Your basket is empty
D-Link Wireless Cloud Camera
Quicklinx: B7TMWS00 Mfr#: DCS-930L/E
£33.66 ex VAT
£40.39 inc VAT
The DCS-930L, Wireless N Home Network Camera, is a versatile monitoring solution for your home or small office. With mydlink included, this camera provides the simplest way to access and manage your camera, whether via your computer or app on your iPhone, Android or tablet. No technical knowledge required!
Connecting a camera to your network and accessing it has traditionally required complex configuration. Thanks to mydlink home monitoring is now made simple.
mydlink makes it easy to access your camera from wherever you are, whenever it's convenient for you- for free. A step-by-step guide has your camera up and running in a matter of minutes. Then via a simple website you can set up a mydlink account allowing you to view and manage your camera from any Internet connected computer. If you have more than one camera, you can add it to your existing mydlink account and watch all your cameras from a single location.
Accessing your cameras on the go is easy too. Just download the free mydlink app for your iPhone or Android and you can quickly and easily view your camera feed from anywhere with a wireless or 3G connection.
This camera includes additional features such as motion detection and email alerts, via the User Interface. This makes the camera a truly comprehensive home monitoring system for those that want to do more.
You can easily set up a detection area (i.e. a window, or your garage door) on the camera's User Interface, so that emails will be sent to you to notify you of any motion detected.
You can also view up to 32 cameras from a Windows computer using the included free D-ViewCam software (DCS-100). D-ViewCam also has a robust set of features including centralized alert management and video/audio recording.
The DCS-930L camera includes Wireless N technology for wider coverage around your home. Wireless N also allows you to stream high-quality video to remote sites over the Internet. A Site Survey feature also allows you to view and connect to nearby wireless networks with ease. The camera furthermore comes with a standard Ethernet port for connections to traditional wired networks.
D-Link DCS 930L mydlink-enabled Wireless N Home Network Camera - network surveillance camera
Network surveillance camera - fixed
Audio
Yes: built-in microphone
6 cm x 2.7 cm x 9.6 cm
77 g
Wired, wireless
Camera
Max Resolution
640 x 480
Optical Sensor Type
CMOS - 1/5" - 640 x 480
Minimum Illumination
1 lux - colour - F2.8
Lens Iris
F/2.8
Ethernet 10Base-T/100Base-TX, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
1 - network cable - external
Voltage
DC 5 V
Date/time stamp, e-mail alerts, image flip, image mirror, automatic electronic shutter, upgradable firmware, Wi-Fi Protected Setup (WPS), auto gain control, auto white balance
Environmental Parameters (operating)
0 °C - 40 °C; 20 - 80% (non-condensing) relative humidity
Audio Support
Wired, wireless
6 cm
2.7 cm
9.6 cm
77 g
Europe
Camera
Colour - fixed
Digital Video Format
MJPEG
Max Digital Video Resolution
640 x 480
Digital Zoom
4
Video Capture
160 x 120 @ 30 fps , 320 x 240 @ 30 fps , 640 x 480 @ 20 fps
Supported Image Formats
JPEG
RAM
32 MB
Flash Memory
4 MB
Image Sensor
640 x 480 CMOS 1/5"
Lens Construction
Lens Iris
F/2.8
Horizontal Field of View (degree)
45.3
Vertical Field of View (degree)
34.5
Network Interface
Network Protocols
DDNS, DHCP, DNS, FTP, HTTP, NTP, SMTP, TCP/IP, UDP/IP, ARP, ICMP, UPnP, IPv4, PPPoE
1 x network - Ethernet 10Base-T/100Base-TX - RJ-45
Stand
1 x network cable - external
FCC Class B certified, C-Tick, IC
Power Requirements
DC 5 V - 1.2 A
Power adapter - external AC 120/230 V (50/60 Hz) 2 Watt
Software Included
D-ViewCam
Microsoft Windows Vista / XP / 7
Relative Humidity (operating)
Brand: D-Link
Price Range Ex VAT: 0 - 50
